  • SN95 4.6L Mustang Tech
please help,what am i missing here
  • Thread starter Thread starter rockyracoon
  • Start date Start date Jan 7, 2011
R
rockyracoon
874
27
49
margate NJ
Jan 7, 2011
  • Jan 7, 2011
im in the middle of a T-3650 swap in my 96 GT (which was an automatic)
I had the trans in place with a couple of bolts loosly on one side,but I noticed that the shift fork didnt have very much travel before it hits the case,in other words it seemed to me that the fork was too far forward when the T/O bearing would contact the fingers of the pressure plate thus only leaving a coupla inches of travel before it goes against the case in the front.
also what would keep the fork from sliding in and out,towards and away from the input shaft.
do the p-plate fingers look they should be further out?
here is a few pictures
http://i583.photobucket.com/albums/ss277/fordguy12/Picture019.jpg
http://i583.photobucket.com/albums/ss277/fordguy12/Picture018.jpg
http://i583.photobucket.com/albums/ss277/fordguy12/Picture020-1.jpg
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 7, 2011
  • Jan 7, 2011
The Mustang's design has the TOB in contact with the clutch fingers all of the time. It's one of the reasons why the Mustang is so hard on TOB's.
The TOB is held against the fingers by the spring pressure of the automatic adjusting clutch quardent. So there isn't susposed to be ANY space between the TOB and the fingers.
Check to see that the shift fork is fully inserted onto the pivot. It can be difficut to tell if the pivot ball is between the holding spring and the fork itself. The spring and pivot ball restrains the shift fork in/out.
Check to be sure the friction disk is installed in the correct direction.
R
rockyracoon
874
27
49
margate NJ
Jan 7, 2011
  • Jan 7, 2011
well it seems that it may be alright.
I just went out and reinstalled the trans,and the T/O bearing contacts the p-plate fingers when the fork is approx in the middle of the little opening of the trans,it seems like there may be enough travel after all.It may have been because I didnt have the top bell housing to block bolts,and the trans was hanging away from the block a little.
Help I want to put this T5 in our Cobra II
  • 2Blue2
  • Jun 27, 2020
  • 4 5 6
23K
1974 - 1978 Mustang II Talk & Tech Jun 29, 2024
LILCBRA
The Dreaded Hanging Idle, I Am At My Wits End! Help
  • Shouter
  • Apr 5, 2015
22K
SN95 4.6L Mustang Tech Aug 15, 2019
sppedstr144
Diy 87-93 Mustang Instrument Cluster Led Upgrade And Triple Guage Pod Install
  • stang89bidges
  • Nov 30, 2015
20K
Fox 5.0 Mustang Tech Aug 11, 2024
Mindseye007
R
cross member for t-3650 swap into 96 gt
  • rockyracoon
  • Jan 7, 2011
SN95 4.6L Mustang Tech Jan 8, 2011
wmburns
1966 restoration / resto-mod
  • cornholio
  • Oct 11, 2010
  • 2 3
7K
1965 - 1973 Classic Mustangs -General/Talk- Dec 30, 2010
edgars23
