Hey guys,
I'm trying to install a set of Steeda upper and lower control arms, and have hit a major roadblock. For the life of me I cannot get the rear bolt (axle side) out for the stock rear lower control arms.
I have the nut off the rear control arm bolt, and can get the bolt to spin when turning it with a socket. I also have the shock unbolted with one floor jack supporting the axle, and another floor jack putting slight upward pressure on the control arm. I also tried various combinations of upward pressure between the two jacks.
I just cannot get the bolt pushed out of the control arm. I even tried taking off the caliper, rotor and brake backing plate off to give me good access to the bolt. I can't get the bolt to budge even when pounding on it with a 3lb sledge.
Does anyone have any tips short of cutting these off with a sawzall? I'm thinking that there's corrosion between the inner bushing shell and control arm bolt, but I'm not sure what to do about it.
wouldn't go in but 1/3 of the way
