Please Help with problem
  • Thread starter Thread starter mytight95
  • Start date Start date Dec 20, 2004
mytight95
2,605
Dothan,Al
Dec 20, 2004
  • Dec 20, 2004
Someone please tell me what some reasons are that would keep the car from getting spark at the coil.......i have tried the ignition module with a know good one, haven't tried a different dist yet......I hae tried a New coil that works on another car......
Are there any fuses that are related to the ignition, i checked the fuse panel etc, and i didn't notice anything......ami missing something here.......
!!!!!!!PLEASE HELP!!!!!!!!
things we have tried now.....
ccrm
ignition module
coil
battery
ran new and checked existing coil
distributor
fuses and relays.....replace with new just in case....
anythign else we could think of we tried......
someone help come up with something please....
BTW this is on a 94 cobra.....
thanks for help in advance
jason
HISSIN50
34
129
Dec 20, 2004
  • Dec 20, 2004
on foxes, there is a fusible link for the ignition.
good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 21, 2004
  • Dec 21, 2004
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
For a 94-96 model Mustang see http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for wiring diagrams
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
mytight95
2,605
Dothan,Al
Dec 21, 2004
  • Dec 21, 2004
the only thing that hasn;t been changed or checked on that list is the computer............only because of a lack of availibility of one to swap in there
jason
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 21, 2004
  • Dec 21, 2004
Check the voltages per the test path & post your results.
J
JB66
565
New York
Dec 21, 2004
  • Dec 21, 2004
Is the car equipped with an alarm?
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Dec 21, 2004
  • Dec 21, 2004
MYTIGHT95,
I experienced the same problem a few years back with my 95 Mustang. I swapped every ignition part that jrichtor said except for the computer. I found a used T4M0 (Mustang 5 speed) computer on Ebay and that was the problem. Turns out that after my trans swap, I was still using the auto computer. Car did not like it and fried the computer. Once I put the 5 speed T4M0 in, it never gave me any spark related problems again.
I found out that the dealer only charged $225 for the computer (ONLY) and I looked for a used one. I think that you could find a 94-95 Cobra computer easy on Ebay since the computers for those years sucked performance wise.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
