Please Help With Vac Leak
  • Thread starter Thread starter JerryDaugherty
  • Start date Start date Dec 13, 2005
First Prev 2 of 2
J
JerryDaugherty
309
Near Dallas
Dec 20, 2005
#21
  • Dec 20, 2005
  • #21
HERE ARE THE CODES
85 Canister Purge Solenoid Circut Failure wtf ?
31 EVP/PFE Circut Below Minimun Voltage ?
54 Intake Air Charge Temperature Sensor Circut Open. Airflow Sensor Out of Range?
91 Shift Solenoid SSI Circut Failure?
These were done while vehicle was off. The book with the code reader said to fix these problems before doing an Engine Running Test.
Any and all help will be greatly appreciated. Thanks!
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Dec 20, 2005
#22
  • Dec 20, 2005
  • #22
I dont know how or why, but i had a loud whistling sound coming from my car and it turned out to be the vacuum hoses under my dash. Go figure. But i replaced on of them and the whistle went away. The last time i had a vacuum leak in my manifold my car idled at 4K, imagine that. It was the side cover gasket on the upper manifold. I took it off and put in some silicone and it ran fine from there on.
BlackGT89
774
Huntsville, AL
Dec 20, 2005
#23
  • Dec 20, 2005
  • #23
Is it possible your IAC Temp Sensor could have backed out of the intake far enough for the threads to be sucking air ? The location would be close to where you are hearing the sound from.
HISSIN50
34
129
Dec 20, 2005
#24
  • Dec 20, 2005
  • #24
IAC and ACT are two separate components.
J
JerryDaugherty
309
Near Dallas
Dec 20, 2005
#25
  • Dec 20, 2005
  • #25
i just put a brand new air intake temp sensor bla bla in there and threaded it in nicely... and when i try and feel around there nothing changes.. i talked to a dude at ford today he has worked on several 5.0 and does modifying... he said all the codes i got were just codes do to not haveing any smog and egr gear on there. and that they would stay there untill i put the smog **** back on.
J
JerryDaugherty
309
Near Dallas
Dec 20, 2005
#26
  • Dec 20, 2005
  • #26
is it true that if the check engine light is on. the car is in open loop? whenever the CEL is on your in open loop the entire time?
HISSIN50
34
129
Dec 20, 2005
#27
  • Dec 20, 2005
  • #27
Not true.
vristang
4,933
101
124
Seattle
Dec 20, 2005
#28
  • Dec 20, 2005
  • #28
I'll call bs on the Ford tech you spoke to.
I have removed all of my emissions at this point. No air pump, no cats, no egr. This is going to change in the near future. I was just under time constraints when doing the 351w conversion.
The only code I get is for the egr. Nothing else.
Maybe there is some difference between year of car, blah, blah, blah. But in my experience most Ford techs will talk out their @$$. Yes, my opinion is biased, as I have had some bad experiences, and have had friends who have worse experiences with Ford.
I would suggest looking into each one of the codes individually. It will be time consuming and a pain, but should be worth it.
J
JerryDaugherty
309
Near Dallas
Dec 21, 2005
#29
  • Dec 21, 2005
  • #29
yea but all the codes i got no matter wut the dumb ass ford guy said are kinda insignificant... i mean yea they should be fixed... but they arent serious enough to make my car run how it does... and have we forgot the massives whistling noise? where can it come from? but it doesnt matter to me anymore as im done with this car alltogether. im not a quiter. as this is the same engine that was in my previous 92 that i built myself but ever since it went into this car it has had serious problems and serious cash has been dumped into it. I cant afford this headache any longer. Im living with my grandparents becuase i cant afford rent with this POS sucking all my money away. This is the exact motor and everything that was in my other 92 gt and never had any probs. Therefore the car is gonna be parted out. Bumper to bumber engine, trans, rear ect. EVERYTHING. Imma call this place about a garage to rent while i strip it down. so if you are interested look in the classifieds on the board for anything you need. the entire car is going out piece by piece. hopefully i can get it as close down to the frame/shell as possible.
J
JerryDaugherty
309
Near Dallas
Dec 21, 2005
#30
  • Dec 21, 2005
  • #30
or pm me for anything you wanna get a jump on before i list anything.
BlackGT89
774
Huntsville, AL
Dec 21, 2005
#31
  • Dec 21, 2005
  • #31
My bad, I meant ACT - Air Charge Temp sensor.
Jerry, sorry we couldn't find/fix your problem. These cars are actually cheaper than average to own and operate, at least mine has been. The bang for buck is hard to beat. Good luck with the parting out.
First Prev 2 of 2
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech 58 minutes ago
AlexM556
A
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
