bill302 said:i guess the rotor turns when you turn the distributor gear? and if it is a broke timing chain or timing chain gear the heads will have to be removed to inspect for broke or bent valves,pushrods ect....
dwhiskie said:It turns when its out of the car When I put it back in it does not turn.
well that rules out a broke distributor shaft it more than likely what 95GTAODEdwhiskie said:It turns when its out of the car When I put it back in it does not turn.
bill302 said:you really need a chilton or haynes manual from your local parts store they explain these proceedures properly and list the torque specs.ect....
bill302 said:sorry dots will face each other and both intake and exhaust valves on #1 piston will be closed.... how high were rpm's when it quit
