please help!!
02mustangbb
9
i go to put my windows down and my drivers side window will go down but my passanger side wont. everything else works but that one window my car is an 02 Gt i have no idea were to even start looking to find out whats wrong any help would be appreciated
both switches are like that its in a garage it stays about 40 degrees so it not real cold i try playing with the switches for a while it worked fine about 3 weeks ago so i dont know what could have happend
Window motors not working are common.
Usually it is NOT a bad motor.
Here are some things to consider:
-sometimes the rubber along the base of the window will hang up the window's movement and cause a overload breaker to trip
-the breaker is self resetting and will reset when things cool off so sometimes just waiting a while will fix
-slamming the door a couple times can correct the situation
-as a last resort pull the door panel and tap on the motor with a long handled screwdriver
-use a multitester to determine if the switch and motor are getting power
Hope this helps, first thing I would try is slamming the door a couple times and waiting a while...
