  • SN95 4.6L Mustang Tech
Please I Need help with timing chains
  • Thread starter Thread starter Jkstang78
  • Start date Start date Mar 16, 2008
Jkstang78
1,510
long island N.Y.
Mar 16, 2008
  • Mar 16, 2008
Hello everyone, heres the deal. My girl blew her motor in her 03 GT. We pulled the motor out and took it apart. I marked the timing chains with nail polish on the 2 cam shafts and links on the chains. I also did the crank sprocket and chains.
Crank keyway was straight up at 12 o-clock. We got a 02 short block. Now I am strating to put this motor back together.
My ? is can I put the crank back to 12 o-clock and just put the timing chains back on the same way. Will this be ok?
Thanks Jason
SilverBullet00
1,150
Wichita, KS
Mar 16, 2008
  • Mar 16, 2008
I believe they call 12 oclock "safe mode" on our motors.. so you should have a problem as long as you match the timing marks up. MAKE SURE the chains don't slip! this has happened to a couple people, and you will take some valves/pistons out of commission.
Generally you want to time the motor at TDC, but as long as the marks are lined up you should be good to go. Once you get the chains, guides, tensioners back on give the motor a couple turns to make sure the chains dont slip.
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Mar 17, 2008
  • Mar 17, 2008
also, just a side note, if you fold the chain in half, the links at opposite ends are the ones that should line up with the marks on the gears.
also, make sure that the marks on the cam gears are facing in almost the same position. they wont be exact but close. I say this because when I did mine I just assumed that there was only one way the marks on the chain would line up with the gears, but I was wrong. one cam can be positioned correctly and the other could be off by 180 degrees and chains still line up with the marks on the gears. and surprisingly the engine will still run, but only the 4 cyl. on the correct side will fire at the right time.
ask me how I know... lol. at least it was the only wrong way it could be without hurting anything.
Jkstang78
1,510
long island N.Y.
Mar 17, 2008
  • Mar 17, 2008
Thanks for all the info guys.
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Need urgent help. Timing chain sprocket. VIDEO..
  • 2003 mustang gt modded
  • Jun 23, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
Chevy Equinox- Devil in Disguise?
  • RaggedGT
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Jul 31, 2025
RaggedGT
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
