Please Identify this Caliper
  • Thread starter Thread starter onepostwonder
  • Start date Start date Jun 30, 2009
O
onepostwonder
  • Jun 30, 2009
Associated Markings:
Made in Australia
K247-045C
No 4611693
No 4261444
PBR
I think that these are Cobra Calipers but I'm not sure. They're too small to be the 99+ GT PBR calipers.
Thanks.
stykthyn
5,232
2,652
223
gainesville
Jun 30, 2009
  • Jun 30, 2009
94-98 cobra is what it looks like
Duncan McDougal
99
Gainesville, FL
Jun 30, 2009
  • Jun 30, 2009
From what I have found they appear to be cobra. LINKY
A weird thing though is that apparently the part number for 99+ brakes is K247-047C, but when I checked on my 01 I didn't see any casting numbers. (I didn't take the wheel off though.
Second number is:
" Disc brake assembly
United States Patent 4261444
Abstract:
The invention provides an aluminium alloy disc brake assembly that overcomes rigidity problems encountered with the prior art whereby the improved assembly is constructed within a specific combination of housing, pad and piston dimensions by which the profile of the housing is circumferentially lengthened and reduced in height, the center of effort of the piston is raised with respect to the axis of rotation of the disc, and the disc pad ratio is reduced."
Third Number:
" Caliper disc brake
United States Patent 4611693
Abstract:
A sliding caliper disc brake including an anchor bracket adapted to be mounted in a fixed relation to a motor vehicle, the anchor bracket having a pair of facing slideways arranged substantially parallel to the axis of a disc with which the brake is to be used, inboard and outboard friction pads adapted to be brought into frictional contact with opposite faces of the disc, each pad being attached to a backing plate and each backing plate terminating at each end in an abutment portion slidable in one of said slideways and a caliper housing including at its inboard end a cylinder in which a piston is slidable, the piston being attached to the backing plate of the inboard pad, a bridge portion extending outwardly and having at its outboard end, attachment means attached to the backing plate of the outboard friction pad, the arrangement being such that on operation of the brakes, sliding motion of the backing plates is guided by the slideways on the anchor plate, wherein the shape of the slideways and the abutment portions of the backing plates are such as to permit the caliper housing together with the back plates to be partially rotated in relation to the anchor bracket about an axis adjacent and parallel to one of the slideways to permit removal and replacement of the friction pads and their backing plates."
Admin Dude
Jan 4, 1985
43,585
21,749
234
Box behind Walmart
Sep 4, 2011
  • Sep 4, 2011
So do these calipers fit the same brackets as the Cobra calipers we're used to using for 5 lug converts?
I've got a set of these same calipers but no brackets. What brackets do I require?
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 4, 2011
  • Sep 4, 2011
Those calipers are 99-04 cobra/bullitt or Mach 1 calipers. 40.5mm pistons.
You can use any 94-04 cobra caliper bracket, pads and hardware with them
Admin Dude
Jan 4, 1985
43,585
21,749
234
Box behind Walmart
Sep 4, 2011
  • Sep 4, 2011
Thanks 5L. Do you happen to have a part # for the correct bracket? I see a couple of folks on Ebay selling brackets but the pictures don't match the brackets they're selling.
Safer if I know the part number(s) for the brackets that I need.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 4, 2011
  • Sep 4, 2011
I don't unfortunately. Only set I have is currently on the car...so makes it tough to get numbers
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Sep 5, 2011
  • Sep 5, 2011
i have not found any way to get the front brackets seperatly from the calipers, i went through this a couple months ago when i had failure, ended up having to order a whole new (reman'd) caliper through oreilly's, they have both with and without brackets, but not just the brackets (which is what i needed).
btw, just noticed that is one long run on sentence. sorry, too lazy to fix.
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 5, 2011
  • Sep 5, 2011
I have a set of 04 cobra calipers sitting downstairs, ill see if I can get a part number off the brackets when I get off work
Admin Dude
Jan 4, 1985
43,585
21,749
234
Box behind Walmart
Sep 5, 2011
#10
  • Sep 5, 2011
  • #10
Chuckman...
I'm working with a source for a set of these brackets now. If it pans out, I'll send you a link. Drop me PM so that I don't forget who it was that was looking for them.
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 5, 2011
#11
  • Sep 5, 2011
  • #11
The only stampings I can find on the caliper bracket are on the bottom of the outside lip, says BTR S over on the left then it says 26H2 8 L on the right.
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 5, 2011
#12
  • Sep 5, 2011
  • #12
Oh and those numbers you posted are the same ones on my 04 Cobra caliper
Admin Dude
Jan 4, 1985
43,585
21,749
234
Box behind Walmart
Sep 5, 2011
#13
  • Sep 5, 2011
  • #13
SWEET! That's the first definitive answer I've gotten back from these calipers. I guess it's an odd-ball part number.
Thanks ID89!
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 5, 2011
#14
  • Sep 5, 2011
  • #14
Not a problem
Chuckman
1,604
1,002
173
st. louis, mo
Sep 6, 2011
#15
  • Sep 6, 2011
  • #15
Noobz347 said:
Chuckman...
ive got my problem sorted out already, i just grabbed a whole new caliper. thanks for the offer though.
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
