PLEASE SOME ONE HELP!!!!!!!!
  • Thread starter Thread starter jb1dsl
  • Start date Start date Oct 27, 2004
jb1dsl
566
Marianna, Fl.
Oct 27, 2004
  • Oct 27, 2004
I was putting my water pump back on my 289. I put gasket sealer on the pump and put it to the block. i began to put the bolts in and started them all. I found that one bolt did not want to snug up so i tightened it some more but then i thought about it, that was one of the bolts that holds my alt bracket. I pulled the bolt back out and water leaked out of the hole (see pic below). I thought that was weird, does this bolt hole usually have water in it. I know it is the hole right by the hose going to the radiator, but i do not remember it being wet. If it is not i have messed up big time,a.k.a. punched through a water jacket. please someone help!!!!
jb1dsl
566
Marianna, Fl.
Oct 27, 2004
  • Oct 27, 2004
i know it is a crude pic but i was in a hurry
65fsbkhipo
1,296
Tampa, FL
Oct 27, 2004
  • Oct 27, 2004
Stands to reason, if once your bracket is on and the bolt is in, then no leak to the outside. Can you push a screw driver all the way through? One thing I dont get is...if your water pump is off, how can there be water in the block. Seems to me not a problem at this point without other info.
jb1dsl
566
Marianna, Fl.
Oct 27, 2004
  • Oct 27, 2004
bracket is back on but i have not fired the car up. i did not see it leak after i put the bracket back on. there is still water in the block even after you take the pump off right? water jackets run throughout the block so i guess it would still have water in it
D
D.Hearne
11,730
south louisiana
Oct 27, 2004
  • Oct 27, 2004
You need to put thread sealer on some of the bolts. they're open to the water jackets on the backside. If you don't use thread sealer, they WILL leak later on. And also be extremely careful you don't over torque those long 5/16 bolts, they break very easily.
jb1dsl
566
Marianna, Fl.
Oct 27, 2004
  • Oct 27, 2004
THANK YOU D HEARNE THAT IS THE ANSWER I WANTED TO HEAR. IM GOING TO FIRE IT UP TOMORROW AND I HOPE ALL GOES WELL.
D
D.Hearne
11,730
south louisiana
Oct 27, 2004
  • Oct 27, 2004
No problemo, glad to help. Good luck.
HistoricMustang
2,359
Confederate States of America
Oct 28, 2004
  • Oct 28, 2004
Hearne is correct again.
When gaskets are involved. Such as water pump and rear end, I always use a lite coat of sealer on both metal surfaces, just in case. The sealer will also hold your gasket in place while you try to assemble the parts.
HistoricMustang
www.historicmustang.com
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
