I was putting my water pump back on my 289. I put gasket sealer on the pump and put it to the block. i began to put the bolts in and started them all. I found that one bolt did not want to snug up so i tightened it some more but then i thought about it, that was one of the bolts that holds my alt bracket. I pulled the bolt back out and water leaked out of the hole (see pic below). I thought that was weird, does this bolt hole usually have water in it. I know it is the hole right by the hose going to the radiator, but i do not remember it being wet. If it is not i have messed up big time,a.k.a. punched through a water jacket. please someone help!!!!
