plug gap measurements .054?
  • Thread starter Thread starter chad935.0lx
  • Start date Start date Nov 8, 2005
C
chad935.0lx
  • Nov 8, 2005
so we set our plug gap .054 is this right for a 93 lx 5.0?
C
chad935.0lx
  • Nov 8, 2005
also does anyone know where i can find vacuum diagnostics
04sleeper
2,674
14
89
Dallas, TX
Nov 8, 2005
  • Nov 8, 2005
I have always used .45 with stock ignition. Some use more.
DTT92LX
185
Downingtown, PA
Nov 8, 2005
  • Nov 8, 2005
Book says .52-.56. I use .54
What kind of vac diagnostics? You looking for a diagram?
sunil6784
620
Boston, MA
Nov 8, 2005
  • Nov 8, 2005
most use beteen .050 and .056 w/ no power adders
HISSIN50
34
129
Nov 8, 2005
  • Nov 8, 2005
cool - I use the same exact gap as Kevin. It allows for a slightly weak ignition and gap erosion.
What do ya mean about vacuum diagnostics? Like how to do it, how to interpret, etc?
Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 9, 2005
  • Nov 9, 2005
Good luck.
The Factory Engineers designed into their specs for gap errosion and if you have weak ignition parts, you should think of replacing the coil, plug wires, cap and rotor and you will be good to go!
HISSIN50
34
129
Nov 9, 2005
  • Nov 9, 2005
Shaker, the arguable gain from slightly larger gaps are debateable IMHO. I have, as perhaps you also have, seen some dyno runs which reveal this (the trend to run the largest possible gap is one that might change at some point here, akin to too much timing advance).
I had no issues with running an 0.060 gap (did it when I got the car) but simple choose to do what I do. (I dont have a weak ignition and did not say I did. But some folks do and while mine works fine, most of the components have 150K miles on them). To each his own.
Since you say the gap erosion is figured into the specs, do you know how much erosion they factor for (over the life of a plug) and in what conditions that spec was related (specs are normally created for new motors with near a perfect efficiency balance. Most of our motors are not that way). So I guess we would need a new motor to extrapolate the specs.
Like I said, to each his own.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 10, 2005
  • Nov 10, 2005
I wasnt trying to start an argument. Gap errosion was figured by the Engineers over the 30,000 Mile change period. I would bet most guys take better care of their Mustangs and do not go the entire 30,000 Miles before changing plugs, so that should more than make up for a motor that is broken in with a few miles.
04sleeper
2,674
14
89
Dallas, TX
Nov 10, 2005
#10
  • Nov 10, 2005
  • #10
Funny, under the hood of my 88GT and 89 Coupe, it says .44-.46
Not sure which book states that.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 10, 2005
#11
  • Nov 10, 2005
  • #11
Kevin -- I'll bet you it doesn't say .44-.46; but rather .044-.046". I think I'll win the bet.
Anywhere in the .044-.054" range ought to work just fine guys. If your ignition components are 'fresher' run it to the higher side. If they're more tired, run to the lower side. If possible, cut back the ground electrode on the plug (Dremel works fine) so you expose more of the plug tip -- allows a bit more of the spark to be exposed to the mixture.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 10, 2005
#12
  • Nov 10, 2005
  • #12
Maybe the earlier 5.0s had a smaller gap. Under the hood of my 92 GT it says .052 - .056, the Owners Manual says the same, and my Ford Service Manual also says the same.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 10, 2005
#13
  • Nov 10, 2005
  • #13
My car ran better with a gap in the upper .40's when I had the stock heads.
1988WHTGT
270
Guyton, GA
Nov 10, 2005
#14
  • Nov 10, 2005
  • #14
What about Edelbrock performer rpm heads. I'm using autolite 3924's and have stock ignition.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 11, 2005
#15
  • Nov 11, 2005
  • #15
Try .045
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 11, 2005
#16
  • Nov 11, 2005
  • #16
Generally speaking -- the bigger, fatter spark you can generate in the cylinder, the better off you are. What that generally means is you should OPEN UP the gap until you find that it runs worse, then back off a bit - the bigger the gap, as long as the system has the energy to jump the gap, the bigger the spark. There isn't a one size fits all on this -- you can each experiment and see what works best. But you won't find too many folks below .045", and you won't find too many bigger than .060".
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 11, 2005
#17
  • Nov 11, 2005
  • #17
Under the hood on my 88LX, it says 0.052"- 0.056"
04sleeper
2,674
14
89
Dallas, TX
Nov 11, 2005
#18
  • Nov 11, 2005
  • #18
You are correct.
You know what I meant.....
Dual sync plug gap
  • 387lx
  • Jan 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 1, 2026
Bullitt347
W
New plugs, wires, dist cap and rotor, now randomly stalling
  • WhiskeyFoxTrot
  • Oct 12, 2024
Fox 5.0 Mustang Tech Oct 15, 2024
WhiskeyFoxTrot
W
  • Mindseye007
  • Aug 16, 2026
Mindseye007
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Best plugs for carb'd roller
  • forango
  • Nov 21, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
HotFox
