- Nov 8, 2005
- 3
- 0
- 0
HISSIN50 said:cool - I use the same exact gap as Kevin. It allows for a slightly weak ignition and gap erosion.
What do ya mean about vacuum diagnostics? Like how to do it, how to interpret, etc?
Good luck.
89sleeper said:Funny, under the hood of my 88GT and 89 Coupe, it says .44-.46
Not sure which book states that.
1988WHTGT said:What about Edelbrock performer rpm heads. I'm using autolite 3924's and have stock ignition.
You are correct.Michael Yount said:Kevin -- I'll bet you it doesn't say .44-.46; but rather .044-.046". I think I'll win the bet.
Anywhere in the .044-.054" range ought to work just fine guys. If your ignition components are 'fresher' run it to the higher side. If they're more tired, run to the lower side. If possible, cut back the ground electrode on the plug (Dremel works fine) so you expose more of the plug tip -- allows a bit more of the spark to be exposed to the mixture.
