Hi I had a couple error codes on my mustang... the one refered to the throttle position sensor.... which I checked the voltage on and it seems to be ok.. at
.7volts. If it is getting the right voltage or putting out the right voltage could it just be a faulty throttle position sensor... There are some throttle bodies that come with the spacer and the sensor.. Would that possibly solve my idle problem... Already went through the checklist....
Another thing referes to a error message I got about a air valve or something on the passenger side of the car.. There is two plugs going into the thing I think the error was refering too but there is a plug dangling there that is unplugged and I can't see where it should be plugged into.. It has 2 pink wires and a green wire.. right on the inner well on the passenger side near the firewall... Any help???
