I have a set of heads that I need to cap the holes at the back of the motor where the air pump tubes bolt up and also need threaded inserts to mount the accessories on the front of the engine. I have heard poeple talk about putting a short bolt or broken off spark plug in there before. Now I dont plan to put a spark plug in there but I tested it to see if it fit so that I could find an appropriate size bolt but the plug is too small and I cant seem to figure out what size bolt it takes. I also tried a helicoil for the size of the accessory bolt on the front of the head but it fit too loose. Is this some oddball thread or does anybody know exactly what size it is? I would use the threaded inserts that ford sells but they are $15.50 each! I can think of alot better things to spend $60 on. Does anybody else sell the inserts or are there other options?
