- Feb 11, 2007
- 763
- 3
- 18
hello,
my buddy has a lincoln lsc race car with the 5.0L. He has a larger TB, cobra intake, heavily worked E7 heads, trick flow .560 cam on the stock rockers (yes, I know. . .)and 30 lb injectors with calibrated mass air sensor. He has 14 degrees in it on 92 octane and he dropped the fuel pressure to 28 to compensate for the injectors, which made the plugs read lean. he richened it up (as i recommended him) to 38 with the vacuum line off, but the plugs still read bone white. what's the deal? I know the setup is nowhere near optimized, but he is low on cash and had to sell his trick set of heads for the worked E7s. He also disconnected the EGR but doesn't get detonation at cruise (as the plugs showed) and the ECM isn't throwing any wierd codes except for soft codes and the EGR. He's trying to get the car dialed in NA for the nitrous later, but I told him not to hit the spray with the plugs still bone white.
As for the trick flow cam, it pulls 16 inches of vacuum at idle and there isn't really any fluctuations on the needle. What should he do (that doesn't involve spending loads of cash)?
