  • SN95 4.6L Mustang Tech
PO1443 - Evap Problem
  • Thread starter Thread starter 281CI96Coupe
  • Start date Start date Oct 24, 2007
281CI96Coupe
233
  • Oct 24, 2007
Here's the story guys....Ever since my Intake manifold cracked I've been getting this Ghost type code. I just call it that because it happens every once in a while but very hard to diagnosis..Since then, I replaced the Intake Manifold with a metal type style crossover but i keep getting this Evap code. I replaced the selenoid twice with a new one. I can't figure out why these keep popping up, mind you that i brought it to a professional mechanic and they cleaned all my connections etc. Can anyone point me in the right direction.
Note: If the car is driven long enough it doesnt even last for a day and CEL turns off, It wont come on till like a week later.
Thanks,
Nate
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Oct 24, 2007
  • Oct 24, 2007
Mine is doing the same thing. Do a search for the code. There is a fix for it here somewhere.
RandyStinchcomb
1,159
Randallstown, Md
Oct 25, 2007
  • Oct 25, 2007
Thanks,
Nate
Nate, it's not just a matter of replacing the canister purge solenoid....there are 2 parts to the sysyem, 1 being the cainster purge solenoid and the other is call the "thermistor probe", which is usally the part that goes bad....the part # is F57Z-14A606-BA and sells for @$20.00
281CI96Coupe
233
  • Oct 25, 2007
Where can I buy this and is it hard to install?
RandyStinchcomb
1,159
Randallstown, Md
Oct 26, 2007
  • Oct 26, 2007
at any Ford dealer, we have them in stock if you need one and it just plugs in line wth the cainster purge solenoid......which I hope you bought a oem Ford one and NOT some aftermarket crap
281CI96Coupe
233
  • Oct 26, 2007
No, I have an oem Ford on the car. Im just trying to figure it out how that goes on because all i remember is the 2 tubes connecting to it and a electrical connection at the bottom. What website i can order from?
RandyStinchcomb
1,159
Randallstown, Md
Oct 26, 2007
  • Oct 26, 2007
web sites?..... I'm on many .........now the thermistor is in line wth the canister purge solenoid...comming off the plenum a short section of vac hose goes to the solenoid...then another section of hose and then the "thermistor"....then out of the thermistor the hose runs into the passenger side fender well and into the charcoal canister and the rest of the EVAC system.........I can be reached at 410-655-2000 parts ext 5618 and Im here from 8am to 4pm mon thru friday
281CI96Coupe
233
  • Oct 26, 2007
Thanks. I will definitely be giving you a call sometime next week...
RandyStinchcomb
1,159
Randallstown, Md
Oct 26, 2007
  • Oct 26, 2007
ok, now I will be out tuesday 10/30 after 12 noon for a doctors appt
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
