- Jul 17, 2001
- 485
- 0
- 0
Sorry I don't have any pics yet, but I got tired of having a dark maroon 3rd brake light lense. The light output was horrible. Looked almost black. 50resto wanted $100 for the Convertible taillight assembly so I decided to do it myself.
Here's what you need and the steps taken. I followed this guide basically. http://www.nseconsulting.com/bmw/hpt.pdf
1. Sandpaper 600 grit, 800 grit, 1000 grit, 1500 grit, 2000 grit etc.
2. Rubbing compound
3. Cleaner Wax
4. Water
I wetsanded using 600, then 800, then 1000, then 1500.
After the 1500 I used rubbing compound with a polishing pad
After that I washed it with water, and let it dry.
Then I waxed the crap out of it, and it looks brand new, and very clear.
To make the restoration worth a flip I sanded the entire reflective surface inside the housing with 600 and proceded used blue painters tape and taped off the lense inside the housing, taped off the outside of the lense, and then hit the plastic housing with chrome spray paint, 2 coats, let dry over night.
Then I removed the tape, put the bulbs back in and it looks sharp.
I even ordered a set of 9LED brake lights that fit in the 912 style socket. I don't know if these are gonna work too well, but the regular 912 bulbs over time had burned a rather large dime sized hole in the housing from the heat. LEDS will be much cooler temperature wise, but might not light up as bright as I want.
921-x9 LED Wedge Base Bulbs from http://www.superbrightleds.com/mini-wedge.html
Keep in mind that Red plastic lenses require RED LEDS.
As noted I will snap some pics, and when the LEDS come in I will update this thread too.
Next I am gonna polish the license plate light covers so that they are clear. I ordered a set of wide angle Single LED Wedge Base Bulbs for the #194 sockets so the plates light up white.
Hopefully the wide angle bulbs don't light up like this.
If they do I won't run them.
http://forums.stangnet.com/showthread.php?t=580742&highlight=LEDs
2. Rubbing compound
3. Cleaner Wax
4. Water
SBLEDS said:Which Color LEDs should I use ?
For best results the LED color should be the same as the lens color. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens.
If they do I won't run them.http://forums.stangnet.com/showthread.php?t=580742&highlight=LEDs
spdfrkaby said:
