  • 1994 - 1995 Specific Tech
Polished Vortech Pullies?
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date Jun 18, 2008
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 18, 2008
  • Jun 18, 2008
Anybody know where you get the pullies for the Vortechs that are Billet aluminum or polished. I called Vortech and they dont seem to know anything about them. I know I have seen them on cars before. I have a stock 3.33 pulley, and I Was interested in getting maybe a 3", but I wanted to get a polished one.
Thanks
RC
Stanger007
2,015
Baton Rouge, LA
Jun 18, 2008
  • Jun 18, 2008
Man I've got an aluminum 3" in the shop but I have no idea where it is from.
Maybe this?
https://www.aspracing.com/ezRetail/search/view.php?msg_id=78
Wes
94GTLaserRC
11,178
Jun 18, 2008
  • Jun 18, 2008
Maybe this?
Wes
Thanks WES...(as always )
I think that's it. I wanted a 3", but for $59, if that is indeed a polished one, I will go for the 2.95. Called them now but no answer...I will try again tomorrow.
Thanks
RC
Stanger007
2,015
Baton Rouge, LA
Jun 18, 2008
  • Jun 18, 2008
No prob Rob.
Heads up that you'll need a slightly shorter belt to run the smaller pullies also. For the 2.95" it is 8-rib 56.5" (#080565) IIRC and you'll want to get the belt tight, readjusting a couple times as it stretches.
Wes
94GTLaserRC
11,178
Jun 18, 2008
  • Jun 18, 2008
Stanger007 said:
No prob Rob.
Wes
Well, I still have a LOT of room to move down on the tensioner, so hopefully that will work. Also, is there anything special I need to do to remove that pulley? On Vortech website is says "caution when removing pulley" Im not too sure what they are implying there.
Thanks
rc
Stanger007
2,015
Baton Rouge, LA
Jun 18, 2008
  • Jun 18, 2008
An impact wrench for the center bolt and a good puller for the pulley. I bent a cheap 3jaw trying to get mine off. A quality 2jaw will do the trick.
Easier to get the pulley off for the first time with the blower off the car on account of the a/c line. If you don't plan on doing the swap now, at least break the pulley free OUT of the car and reinstall it so that next time it comes out easier and you can do it in car.
Wes
9
95trippleblack
60
Chicago
Jun 18, 2008
  • Jun 18, 2008
With a 2.95 you will need a 5080565 (56-1/2") belt. No way the 3.33 belt will fit.
Good place to get a belt
http://www.ryderfleetproducts.com/cgi-bin/ryderfp/products/srm/oid/51210/pn/belt-8-rib-1-1-8-wide-x-56.5long/erm/product_detail.jsp
Pulley ASP510095 I got was black
http://www.jdsperformance.com/index.asp?initemuid=439&fcmd=item&inmake=0
Pull it off carefully with a 2 or 3 jaw puller and put some antiseze on it when reinstalling. Don't forger to loosen the bolt before you loosen the belt. Don't loose the key
Also if you under warranty removing the pulley will void the warranty
94GTLaserRC
11,178
Jun 18, 2008
  • Jun 18, 2008
What key?
The blower is off the car for my engine swap. I guess I can mount on the Vortech ON the engine OUT of the car, then put the belt on it, then take off the pulley.
Thanks
RC
9
95trippleblack
60
Chicago
Jun 18, 2008
  • Jun 18, 2008
94GTLaserRC said:
What key?
Thanks
RC
Their is a key on the shaft that the pulley in on.
No big deal. You need to hold the pulley from spinning when you take loose the nut or just use an impact
S351Saleen77
423
Washington
Jun 18, 2008
#10
  • Jun 18, 2008
  • #10
I use the Reichard Racing "Ultra grip" to stop my belt from slipping. It didn't slip until I went with the 2.95" standard Vortech pulley. The Ultra grips have grooves cut into the pulley that "Grips" the belt (See link bottom right photo). Also I use a Gates or Napa(Made by Gates) belt. The Reichard pulleys also have deeper grooves and the Gates belts fit them. I had a Goodyear Gatorback belt and the grooves are not as deep and it slipped!!
Heres a link http://www.reichardracing.com/pulleys.php
94GTLaserRC
11,178
Jun 19, 2008
#11
  • Jun 19, 2008
  • #11
I saw the link but there are no prices.
On the "key" is that just part of the shaft, like on the Balancer? I was just wondering how that gets lost.
I really dont "need" a smaller pulley....I just wanted one that is polished, so I was going to change while I am at it. With the 331 and stock block limits, I dont know if I want to push more boost.
RC
ProKiller
3,064
15
78
PA
Jun 19, 2008
#12
  • Jun 19, 2008
  • #12
I was going to mention reichard racing as well. I'm pretty sure their pulleys are billet, but like you said they don't have prices. You'd have to call them up
vp5.0
20
laredo, tx
Jun 19, 2008
#13
  • Jun 19, 2008
  • #13
this is where i got mine at a fleabay store
http://cgi.ebay.com/ebaymotors/Powerdyne-Vortech-Mustang-6-rib-and-8-rib-Pulleys_W0QQcmdZViewItemQQ_trkparmsZ72Q3a552Q7c39Q3a1Q7c65Q3a12QQ_trksidZp3286Q2ec0Q2em14QQhashZitem350070939639QQitemZ350070939639
94GTLaserRC
11,178
Jun 19, 2008
#14
  • Jun 19, 2008
  • #14
Im assuming Natural finished is polished?
Also, is the 20mm shaft the one we have?
Thanks
RC
S351Saleen77
423
Washington
Jun 20, 2008
#15
  • Jun 20, 2008
  • #15
You would have to call Reichard Racing I guess. I paid around $100...plus the wasted cost of a Vortech one that slipped!!!
94GTLaserRC
11,178
Jun 20, 2008
#16
  • Jun 20, 2008
  • #16
They just sent me back an Email that the price is $150 each
RC
ProKiller
3,064
15
78
PA
Jun 20, 2008
#17
  • Jun 20, 2008
  • #17
wow. i found a used 2.95 vortech pulley for like 40 shipped on corral a while back. not polished though.
94GTLaserRC
11,178
Jun 21, 2008
#18
  • Jun 21, 2008
  • #18
The ones from the Ebay place are aluminum but not polished. With the amt of money Im pouring into this thing now for a show-looking car, I may just suck it up and go for the Reichard racing one...they are supposed to be better-gripping anyway..Thanks
RC
For Sale Vortech crank and blower pulleys
  • Dontknowchit
  • Sep 25, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 15, 2025
Dontknowchit
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
