Pony Removal.
RonRon2112
Westford
Hey everyone...
my dad has an 04 mach 1, and he wants to remove the pony in the grille but the bolts require a special bit to remove them (they hold the bracket to the grille frame..) where can i find that bit? or how can i remove them otherwise?
thanks
It is a safety torx, which is a torx bit just with a hole in the middle. If you have regular torx screwdrivers like me, then just use a small drill bit (small enough not to mess with the torx slots) just big enough to cover the post in the middle and drill it down. Then You can just use the regular torx screwdriver. My Stock pony only had one in it anyways, I guess it was friday when they put mine on because the other hole was empty.
I just broke mine off? Drilling would be the best option if hes putting something else in its place (IE CDC's Stars and Stripes or that one companys flame pony)
Question.
I was thinking about buying the Stars and Stripes pony for my car for 4th of July only. I would just put it on for maybe 2 weeks around the 4th.
Anyway, does it come with the pony only? or the entrie post so i can just swap ponys? I have the Mach 1 grill in my car. I don't want to be prying the pony off the mount to swap them around...although i could just buy a 94-98 one of ebay for $5
It's a T-25 torx security bit that you need. I just bought a whole set of bits (8 or 9 of em) for $10.00. The MAF is a T-20, I believe...but, as was stated, these parts vary from year to year, sometimes month to month...
The pin in the middle of the bolt opening prevents anyone without the security bit from removing your running horse. I guess they didn't figure that they'd start selling these bits at every hardware store, auto parts store and flea market in the country!
Its just the pony, Honestly if you wanted to do it TEMP, I'd suggest some 3M if youre too cheap to buy the torx bits? I superglued mine on :p If youre stealing it youre taking most of the grille with you
