Poor radio reception/subwoofer air space questions.
The basics: Alpine CDA-9847 head unit, 88 Mustang w/o stock amp. Used a harness adapter and everything works fine, except the radio reception. I double checked my antenna lead at the antenna base on the fender, I also double checked the antenna lead going into the radio. Everything is hooked up fine.
I checked online for customer reviews expecting to see poor reception issues....but nope. Reviews were pretty much all solid.
My old Sony Xplode headunit never had any reception issues, everything came in just fine. I also found a thread on a different car forum that mentioned how peopel forget to hookup the power antenna wire because they assume it means a power retractable antenna, but in a lot of cases it is for a signal booster...or something to that effect. So I went ahead and connected the power antenna lead on the harness to the adapter, but it didn't change anything. I also unhooked the antenna lead from the back of the radio and the loud white noise changed to a lower, slightly different white noise...so it did have some effect on the reception...of course it didn't help.
Obviously I could just have a broken head unit....or broken radio reception thingy inside the radio. But I figured I would throw this to all of you to see if maybe there is something I could be missing. I just can't figure it out. Old radio had great reception, new radio is hooked up in the exact same manner but has pretty much no reception. Odd.
Added: I forgot another question that has nothing to do with the reception, but it is a radio question...
I have a 10" sub in a small box in my trunk. It is a sealed box, and sounds great....when the trunk is open. With it closed it still sounds good, but doesn't hit like it should. You can clearly hear the bass hit MUCH better when you pop the trunk while it is playing. So obviously I have an air space issue, but I don't know how to solve it. I am thinking of removing the rear 6x8s and installing some 5" speakers in the side panels, I am wondering if the speakers being removed from the shelf will allow more air to pass and make the sub hit better...or will the cloth covering the speaker holes keep the air in the trunk? I don't listen to rap or anything, so it's not like I am looking for earth shattering bass hits. I just like to hear and feel the bass drums when I am blasting my metal.
