popping at low rpm
9150ho
83
Just got er done! supercharger is in and the car is running, but its not all right yet. I have the novi 1000, a bosch bypass valve, and the fmu, i think thats about all that would be of relevance. it idles really low at like 500 down to 300 and than will die after a couple minutes or less. and when i acclerate it will stutter and jerk kinda. but its all ok at higher rpm's like if im cruising at around 3000 and up and even under WOT. i really cant take it at wot all the way through the gears because its raining, but any idea on what i can look for with my symptoms? would a vacuum leak cause low rpm troubles but than subside at higher ones?
sean
well the first thing i would do is bump up that idle speed. My car was idleing at 500 for a while and if i hit the gas it would fall on its face. Try setting your idle between 800-1000 See how that does.
