93 Notch
5 Speed
66k
Gt40X heads
B303
Hey guys I recently did an HCI swap on my car. Finally got it running right by adding a 190lph fuel pump. After a 12 mile drive I put it up. When I took it out again a few days later it started sputtering and popping thru the exhaust, and losing power through every gear. It was so bad that I took it home.
* I found out the timing was set to 30, so I fixed that (now at 14).
* I redid the roller rockers and found one with too much shim
None of this fixed it. The car shakes bad at idle and every now and then it will try and cut out.
We looked last night and it seems the new Accel wires are arching all over the place near the headers. Can that be the issue? Why did it just start?
My truck got hailed on so in order to have it fixed I need to drive my mustang
List of parts:
190lph fuel pump
C&L MAF (for 19#)
Stock injectors (55 psi)
Accel coil
New plugs (gap checked)
Reman distributer
Newish TPS
New cap & rotor
Accel wires
And I'm running gt40x aluminum heads with a b303
Thanks doods,
Strype
5 Speed
66k
Gt40X heads
B303
List of parts:
190lph fuel pump
C&L MAF (for 19#)
Accel coil
Reman distributer
Newish TPS
New cap & rotor
Accel wires
Thanks doods,
Strype
