Popping noise coming from under strut bearing bracket?
KIMBO1
Hey fellas, I have a problem that I'm hoping you guys can help me out with. I'm hearing a popping noise coming from driver side around wheel, sounds like its coming from strut bearing? I have a 07 GT lowered using sportline springs and just now started hearing the noise and only hear it when I turn the wheel back and fourth on the driver side, Sound like strut bearing to you guys?
im prety sure its your strut mounts that took a **** the best way to fix the problem is get your self some j&m caster camber plates they usually run around 200-220 for the set but it will definetaley stop the noise
The Pro kit seems to be as low as you can go with a nonadjustable strut mount. Sportlines are too low for the GT 500's and the stock one's. You need to go with any that have adjustment in them. I don't believe you can pick any up for under $300. There's no cheap way the lower your car that much without running into problems. Did you also get an adjustable panhard bar and a camber bolt kit?
