popping through intake under a load and lose of power when hot out !
89lxcoupe
207
harlan,ky
well recently i have noticed that when its hot out or when the engine is hot that i have a lose of power and the engine will pop through the intake at low rpms under a load in 3rd or 4th every now and then not every time and at low speeds in 1st or 2nd it will start bucking, also i drove my buddies gt with tfs heads and all the other supporting mods and i noticed that his throttle repsonse was smoother off idle then mine but other than that my car felt alot stronger !
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
Do not jumper anything to the single black connector. It is the power for the under the hood light. It is in another bundle of wires near the windshield wiper.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
i dought its a worn cam lobe being roller ! and i just looked at the cam about 1000 miles ago when i rebuilt my engine, but it hasn't done it anymore since i have been playing with timing and fuel psi !
