Popping under quick throttle opening
  • Thread starter Thread starter 351Powered
  • Start date Start date Apr 9, 2009
1 of 2 Next Last
351Powered
  • Apr 9, 2009
Hello everyone!
Still having a problem w/ the Mach 1:
Problem: A "popping" noise/small backfire from the carb when the throttle is opened quickly and only quickly. If it is opened slowly the engine will spool up just fine and everything sounds great. The popping happens more easily when the engine is under load. For audio/visual reference please watch this clip:
YouTube - Mach 1 First Run 4 08 09
Car is question:
1973 Mach 1
4160 600cfm Holley
351 C
4 speed
I would really like to get this car to the big show at the University of Maryland (April 26). I'm thinking a valve or timing chain problem off hand?? Please help!! Thank you!!
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 9, 2009
  • Apr 9, 2009
Check the accel pump adjustment. Most Holley-equipped cars can use a lot more accel pump than what comes out of the box. First make sure the linkage for the accel pump has no slop, and if that doesn't help, try a larger squirter nozzle. The larger nozzle lessens the pump shot time, but increases the intial amount, which is what you really need.
2nd Mustang
2,488
Southern California
Apr 9, 2009
  • Apr 9, 2009
Is that popping or pinging?
stonecoldtx
214
Dallas, TX
Apr 10, 2009
  • Apr 10, 2009
That doesn't sound like "popping" to me, it sounds more like a broken piston, because it only occurs under a load . . .
You might want to take a compression test, and maybe try to put it under a load to see if you can determine which cylinder is making the noise.
You may be able to accomplish this by having your emergency brake on with the back end raised, and then have someone rev the engine a bit and let out on the clutch while you or someone else is under the hood pulling plug wires.
If you can make the engine noise occur under those conditions, then it should stop when you pull the plug wire of the bad cylinder.
10secgoal
2,801
San Diego
Apr 10, 2009
  • Apr 10, 2009
WOW, stop running it before you do more damage. Sounds like a bent or sticky valve to me. But either way, you got some work ahead of you.
jcode68
892
Massachussetts
Apr 10, 2009
  • Apr 10, 2009
That sounds really bad, definately stop driving it until you identify the problem. If it is backfiring through the carb, it might be possible that you have the firing order wrong. You should verify the firing order based on the cam you have installed. Eliminating the simple things first is the best place to start. Did you just complete an engine rebuild or something?
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 10, 2009
  • Apr 10, 2009
Holy crap!!! I never watched your vid, but forget everything I said earlier, you have something very unhappy inside the motor. Start by pulling the plugs and I'd bet you find something broken in at least one cylinder.
351Powered
  • Apr 10, 2009
Further info
1) It is defiantly a 'popping' not pinging.
2) It does not only occur under load. You will hear it at idle if you give a quick opening to the throttle
3) It doesn't sound as deep IRL as it does in the video
4) The timing is set and the firing order has been checked several times
5) Put new rotor and cap on today, that seemed to help out a little
6) There is a slight light sounding ticking at idle which is making me think it's a valve
7) Did a compression check:
Cyl______Reading
1________150
2________180
3________150
4________145
5________160
6________180
7________150
8________150
O
Opentracker
20+ Year Stangneter
Feb 4, 2004
516
  • Apr 11, 2009
Advance the timing and see if that helps. If the timing is to far retarded, it will pop though the carb.
It sounds like a rod knock more than a carb POP.
Pull the starter and see if it's hitting the flywheel.
John
351Powered
#10
  • Apr 17, 2009
  • #10
Double checked the timing and it's dead on 16 BTDC right where she's supposed to be. Also tried adjusting the accelerator pump but that didn't seem to make any difference. Gonna pull the valve covers either today or tomorrow, will post again to let you know what I find. Here is another video of idle and the 'pop' I keep referring to:
YouTube - 1973 Mustang Mach1 Engine Troubles
2nd Mustang
2,488
Southern California
Apr 17, 2009
#11
  • Apr 17, 2009
  • #11
That sounds nasty. Hook up a vacuum gauge to a manifold vacuum port. A vacuum gauge is very handy in trouble shooting. It really sounds like something banging around as there doesn't seem to be a stumble when you blip the engine, just that knocking sound.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Apr 17, 2009
#12
  • Apr 17, 2009
  • #12
Hmmm, I suppose it could be some nasty rod knock.
I'd be tempted to look into other areas of your driveline. Could be that the driveline is shifting under load. Driveshaft/u-joint comming into contact with exhaust, etc.
Definately inspect the motor mounts. When my motor mount let go, that's how I knew... the fan started to come in contact with the fan shroud when the engine was under load.
2nd time a mount let go, I wasn't so lucky
hardsy
Melbourne, Australia
Apr 18, 2009
#13
  • Apr 18, 2009
  • #13
sounds like valve knocking on a piston to me!
F
ForceFed70
4,818
BC Canada
Apr 18, 2009
#14
  • Apr 18, 2009
  • #14
If that was the case, I'd expect it to make that sound all of the time. Not just when the engine is under load.
10secgoal
2,801
San Diego
Apr 18, 2009
#15
  • Apr 18, 2009
  • #15
Ehhhhh, dunno. More load = more cylinder pressure. Something that definitely require no more running till it's figured out.
stonecoldtx
214
Dallas, TX
Apr 18, 2009
#16
  • Apr 18, 2009
  • #16
I still say it's a broken piston . . .
351Powered
#17
  • Apr 18, 2009
  • #17
Spent the day talking to several other guys about my problem and they seemed to think it was the accelerator pump or to try using a bigger discharge nozzle, since the one on the 4160 is smaller than what would have been on the stock carb. (Much as you suggested Zoo Keeper) I'll post back after these two things get checked out. If I get a larger nozzle, how much bigger should I go? The 4160 has a .031 should I pick the size the original 750cfm carb would had?
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Apr 19, 2009
#18
  • Apr 19, 2009
  • #18
don't ignore these guys...Most of em have years in the business....i think you're hoping its going to be a simple fix...but i don't think it is. Take the hour to pull the heads off the car and take a look. You'll be able to see if its a sticky valve and what kind of damage has been done.
if it were a pump shot problem, you'd get a sputter and stall...or better yet a backfire (if its too small) because it would be running to lean under load. this sounds like a hard core knock. Whether it be from pining or (most likely) that someone inside your motor isn't a happy camper.
you say its not as bad in person...I say it ALWAYS sounds better in video. video mutes out stuff you wouldn't hear otherwise.
do yourself a favor, pull the heads, and find out.
hardsy
Apr 19, 2009
#19
  • Apr 19, 2009
  • #19
The knock gets faster with the rpm's, definately not a lean pop it's as it's consistent with engine speed and doesn't do it at the hit of the throttle.
I totally agree with Jlang pull the heads and have a look, revving the crap out of it aint gonna fix it!
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 19, 2009
#20
  • Apr 19, 2009
  • #20
Ok, I'm going to give you the benefit of a doubt. Maybe, the video sound is misleading on the severity of the noise. You are the only one on this forum who has actually heard it in real life, so let's just say it is a pop caused by a super lean carb. It could either be a vacuum leak or a lean accel pump causing the pop. You need to make sure it is NOT a vacuum leak before you start tuning it. To do that, try hooking up a hand-held vacuum gauge to a manifold vacuum port. If your car has a stock or mild cam, you should see a steady reading at idle. The idle should not fluctuate, nor should the gauge reading. If you get a fluctuating needle, or the car will not idle on it's own, then replace either the base gasket or the manifold gasket or both to fix the vacuum leak. Once the engine has a good idle, and a steady vacuum reading, you can start to tune the carb. First make sure the accel pump circuit is working as it should, regardless of a small pump shot. Witht he engine not running, and the air cleaner off, look down in the carb and work the throttle by hand, and you need to see a shot of gas coming from each squirter. If you do not, then replace the accel pump umbrella and spring and clean all the passages in the metering block, as well as blow out the squirter nozzle. Then recheck it for an accel pump discharge (once the carb bowls have gas in them again). If you now have gas where you didn't before, drive the car again and evaluate any change.
If the carb still pops, it's time to start tuning. You can either tune the nozzles or the cams or both, but only make one change at a time. I'd start by making sure the linkage is tight on the cam. The cam is located on the throttle shaft near the throttle linkage, and all Holleys have two positions. They are marked "1" and "2". If the screw is in the "1" location, remove it, move the cam slightly until the "2" hole lines up, reinstall the screw, then test drive. You can also swap different cams altogether, and your local parts guy or Summit can help you pick a larger accel pump cam. If you want to swap squirters, then first note the squirter you have by removing it, then noting the number on the side. If I remember right, they are numbered from (I think) 25 to 51. The smaller numbers give the longest shot of gas time-wise, but the smallest amount. Going to a larger number increases the actual amount of gas, but decreases the time of the shot. If it's too lean, go up 2 to 3 sizes and then test drive. If you are doing this on the car, be very careful since there's a tiny washer under the squirter, and dropping it into the motor will make you say lots of bad words. Also, don't rule out timing, check your timing curve before you start to ensure your initial timing is right, and to make sure the advance is working correctly. Hope this helps. Jim
1 of 2 Next Last
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
L
Engine 97 mustang gt manual weird idol when off the throttle and coasting in 3rd, 4th, or 5th
  • Lanezs
  • Jun 9, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
R
Car shuts off under throttle, idles fine. Looking for some pointers.
  • rmarcotte
  • Jul 8, 2023
2K
SN95 4.6L Mustang Tech Aug 1, 2023
rmarcotte
R
