Removing/draining the fuel tank! Need some help!
As promised, here is an update on my POR15 trunk project for the ‘65. The project has been delayed about a week because the car was getting new disc brakes (Granada), tires and American Racing rims!
I made a lot of progress and only suffered one setback that I’m hoping someone can address. Here’s a quick rundown of what I was able to do today:
1. Removed taillights and backup lights.
2. Removed rear valance and bumper (and bumper guard brackets)
3. Used a stiff brush to remove loose paint and black gunk
4. Had to do step 3 a few times to get up all the black tar like gunk that coated the upper side of the wheel well.
5. Using a screwdriver I was able to remove big sections of bondo. It looked like a previous owner applied the bondo as preventative maintenance because I only found one spot where there was an actual hole/rust. Maybe I’ll see more when the paint is removed.
6. A few of you suggested that I remove the fuel tank. I attempted to do this but ran into trouble. I wasn’t able to drain the fuel tank because I couldn’t get the dang plug off! I applied some WD40 and moved on.
7. I removed the gauge wire with no problem but couldn’t figure out how to get the fuel link off. UGGG!!!!
Here are my questions:
a. Is there any other way to drain the fuel tank?
b. How do you get the fuel link off?
8. I tested the Peel Away 7 overnight. That stuff works like a charm. I applied a thin layer around 5:00 and covered it with the “special” tissue paper. Around 2:00 this afternoon, I was able to scrap right down to the bare metal with no effort.
Now, if it I can just get the fuel tank out this project can move forward!!!
Regie
Regie
