ported vacuum vs. full vacuum
  • Thread starter Thread starter calpolymustang
  • Start date Start date Apr 4, 2004
calpolymustang
217
Santa Rosa, CA
Apr 4, 2004
  • Apr 4, 2004
on my edelbrock 1406 600cfm, whats the difference between running off the upper vacuum connection or the lower vacuum connection?
i drive the car as a daily driver that lives stop-light to stop-light on the weekends. right now im running 15 initial, 38 total timming
R
Ronstang
1,294
Houston Texas
Apr 5, 2004
  • Apr 5, 2004
If your talking about the vacuum advance then it needs to be attached to ported vacuum and not manifold vacuum. Ported vacuum will be 0 or very little at idle and increase as speed increases and manifold vacuum is highest at idle and cruise and decreases to 0 during acceleration......so it doesn't seem to hard to figure which vacuum signal the vacuum advance needs now does it?
H
Hydrocarbon
160
Medford Oregon
Apr 5, 2004
  • Apr 5, 2004
I had mine on full manifold vacuum. It seemed to run better there.
bnickel
5,640
lubbock, texas
Apr 5, 2004
  • Apr 5, 2004
if the car runs better with full manifold vacuum, then you either have your initial timing seet too low or the distribitor needs to be recurved. with full mainfold vacuum pulling on the advance you effectively have the vacuum advance locked out at full advance
1970 slantroof
189
Far S.E. Arizona
Apr 5, 2004
  • Apr 5, 2004
Amen to what bnickel said. In this hot country, you will not get by long running the advance off the wrong port. When I got my 65 F-100 with a 352 it had the same symptoms and I resolved it by fixing the distributor and timing it properly.
Howard
H
Hydrocarbon
160
Medford Oregon
Apr 6, 2004
  • Apr 6, 2004
I've since converted to EFI. I decided to let the computer recurve the advance for me.
One thing I did notice when it was carbed. Was if it was on ported vacuum i would get a surge of power at 1500 RPMs. If it was on full vac. it was smoother.
I don't see how having it on manifold vacuum would be a bad thing as long as it doesn't ping. I thought you wanted advanced timing at idle and lite load conditions. Since my cars has 2.73's 35MPH is at about 1200RPMs, and on ported it would only start to get vacuum.
The only down side I can see, is when decelerating it would max out the advance and increase NOx emissions from the increase combustion temps.
Can someone please explain?
G
geegee
2,015
near Oklahoma City, OK
Apr 6, 2004
  • Apr 6, 2004
Ported vaccuum is obtained in the carb above the throttle butterfly whereas straight vaccuum is manifold vaccuum (below the butterfly). Ported vaccuum thus is modulated by the position of the butterfly. If the butterfly is closed, no vaccuum, etc.
351LX
1,007
Regina, Saskatchewan
Apr 6, 2004
  • Apr 6, 2004
I have always hooked mine to manifold as it idles better.Here is a link that describes the difference in non-technical terms. http://www.gofastforless.com/ignition/advance.htm
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
  • dan50
  • Jul 18, 2026
dan50
