  • SN95 4.6L Mustang Tech
Porting and Polishing Help
  • Thread starter Thread starter 97gtconv.
  • Start date Start date Apr 1, 2007
97gtconv.
244
Lock Haven, PA
Apr 1, 2007
  • Apr 1, 2007
I've been porting my P.I. heads on the exhaust side and in the chamber for sometime now to where it looks good (hopefully flows well). I've been using a dremel tool with barrell rollers with rough, mild, and fine and does a good job.
I haven't touched the intake ports at all. i cant get all the way down to the bottom but i've been told to leave them alittle rough to still keep some turbolence. what do you guys suggest? go down as far as i can and work up?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 1, 2007
  • Apr 1, 2007
You should be able to buy some long shank carbide cutting bits that are aluminum specific to work the runners. Go ahead and gasket-match the ports and transition them back to the bowl area. The key to a good port job is consistency and smooth radiuses. Remember, more gains can be made by increasing velocity and flow capability than just volume alone.
97gtconv.
244
Lock Haven, PA
Apr 1, 2007
  • Apr 1, 2007
where would a place have this attachment?
san~man
O-G
A little grass shack on a big lava rock
Apr 1, 2007
  • Apr 1, 2007
You've got a big sack to try and port your own heads.
Just be weary: removing too much material or from the wrong places will hurt your performance.
97gtconv.
244
Lock Haven, PA
Apr 1, 2007
  • Apr 1, 2007
i was shown how to do the exhaust and chamber but never the intake. i'm not worried about messing the heads up...i have a complete set of npi heads that are worked and flow benched that can go on anytime and another set of npi heads that are in pieces that i'm tinkering with. i'm a future technition and not scared one bit.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 1, 2007
  • Apr 1, 2007
Anyplace that sells the Dremel tool should be able to get them for you. Here's a start.....http://www.nscalesupply.com/DRE/DRE-.html
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
  • Gulftown980x
  • Jul 29, 2026
squeak93
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
