Porting heads
  • Thread starter Thread starter DarkMesa8
  • Start date Start date Sep 23, 2004
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
  • Sep 23, 2004
I have an offer to have my Edelbrock heads ported, stage 1. I'm just worried about the stories of heads being ported and people being dissapointed. Is there really that much to gain by a port job in Edelbrock performers?
He is a professional and is well renowned in my city, so I'm not afraid of the quality of work. I just don't want to have it done and wish I had put the money towards AFR 165s.
giddyup306
3,041
Sep 23, 2004
  • Sep 23, 2004
What's the model of the heads? I have a set of #6025's (I forget the new p/n) and got around 30 cfm on the intake side. Went from app 250 to 275-280 cfm.
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
  • Sep 23, 2004
They're the 6037's, not the new ones.
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Sep 23, 2004
  • Sep 23, 2004
you will enjoy the added HP of ported heads. I really dont think that your gonna go wrong with this option. I know you have been debating on what to spend your money on, but i think that this is a wise one accompanied by that custom cam.
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
  • Sep 23, 2004
Is that an FTI cam in your sig? Did you add it independently, if so, what kind of gains did just the cam give?
N8Miller
2,661
Kingston, PA, USA
Sep 23, 2004
  • Sep 23, 2004
in my sig? nah, its a comp cams xe274 cam.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Sep 23, 2004
  • Sep 23, 2004
Find out if the porter has/uses a flow bench. That's really the only way to know what they did before and after the porting. If he doesn't use a flow bench, I'd look elsewhere for your porting help.
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
  • Sep 23, 2004
Changed my mind. I'm going with AFR165's, and he's gonna port and match the Edelbrock intake to the AFR's.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 23, 2004
  • Sep 23, 2004
I though you already had the Edelbrocks? What are the rest of your mods like. Maybe there's no real justification at this point to port them.
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
#10
  • Sep 23, 2004
  • #10
I do, I'm going to sell the Edelbrocks, and use the porting money towards AFR's. The machinist actually told me all he could do is get me to specs of AFR's before he started to sacrafice too much low end torque. HE recommended AFR's to me, and you know that says something when the machinist would rather you spend your money on something better.
Here's the car:
1995 Mustang GT Convertible 5 Speed
Engine: 302ci
Edelbrock Aluminum Performer 5.0 cylinder heads
Crane 2031 cam (.513in/.529ex)
FMS Cobra intake (ported/polished/powdercoated)
1.7 Cobra Roller Rockers
Mac Underdrive pulleys
Mac cold air intake
75 mm Pro-M MAF meter
BBK 65mm throttle body
Summit Racing harmonic balancer
180 degree thermostat
Fluidyne aluminum radiator
Wazee power steering and idler pulleys
Wazee EGR delete kit
FMS high-flow oil pump
FMS windage tray
ARP Bolt Kit
Computer: T4M0
Autologic Custom Burned Chip
Ignition:
MSD 6T Ignition Box
MSD Soft Touch Rev Limiter
MSD 8.5mm Super Conductor Wires
MSD Blaster Coil
Power Adder:
NOS 5115 80/150 Dry Shot
(Soon to be a Supercharger)
Fuel System:
FMS 30lb Injectors
BBK 255lph Fuel Pump
Kirban Adjustable FPR
Autometer Underhood Fuel Pressure Gauge
Exhaust:
Mac 1 5/8" jet-hot coated longtube headers
Mac 2.5" Prochamber Offroad Pipe
Mac Flowpath Mufflers (Dumped)
Transmission/Drivetrain:
Borg Warner T5 Stock Spec
King Cobra Clutch
FMS 3.55 gears
FMS aluminum driveshaft
Welded driveshaft loop
Suspension/handling upgrades:
Welded full length subframe connectors
J&M Caster/Camber plates
Eibach Pro springs
Monroe Sensa-Trac shocks/struts
FMS strut tower brace
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 23, 2004
#11
  • Sep 23, 2004
  • #11
I dunno...I think that unless you can get pretty much what you payed for the Edelbrocks, you're probably better off staying with them. The AFR's are the superior head, but we're only talking by a few horsepower with your current set up.
It's all up to you, but better flow numbers don't always mean better performance. you won't realize the full potential of the heads until you've had the Cobra intake ported as well.
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
#12
  • Sep 23, 2004
  • #12
How true...
Do you think I should just replace the intake with an Edelbrock intake, and have that port matched to the Edelbrock heads? Would I be missing out on much power by just doing that, instead of both AFR's and a port matched intake? (A custom cam is going in, regardless).
I could put the money towards a Wide Band O2 sensor to use in conjunction with my Tweecer RT (I know it says autologic, Tweecer is on my desk next to me here).
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 23, 2004
#13
  • Sep 23, 2004
  • #13
The Edelbrock Performer heads and intake are a pretty good match for the parts that you've got. I don't see you losing out on a whole lot of power compared to the AFR's. Maybe 10-12rwhp at the very most, but then again, you'll also be paying more for the AFR heads and having to spring a few dollars extra to have the Cobra ported to do so. So it’s costing you either way. From my experience the Edelbrock stuff is a pretty clean set up right out of the box. Some port matching between the intake runners on the heads and lower intake manifold may be beneficial, but by no means an extensive amount of porting. You could probably do it yourself and cut the cost even further.
DarkMesa8
1,087
Orlando, FL
Sep 23, 2004
#14
  • Sep 23, 2004
  • #14
Trading the Edelbrocks for the AFR's would cost about $500.
Porting the intake either way would cost $300. No real cost of the intake change... maybe 100 (Its powder coated really nice, so I'm sure somebody will grab it quick and pay).
Keeping the Edelbrocks would save a lot of money. $500hp for 12rwhp doesn't sound worth it at all.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 23, 2004
#15
  • Sep 23, 2004
  • #15
I didn't think so either.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
G
What's it Worth? ⚠️ I have a brand new set of original KPI/Trick-Flow High Port Cylinder Heads, Stage 2 Ported
  • GhstRider68
  • Jul 8, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 8, 2025
GhstRider68
G
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
