Posi or Locker?
First, to bust your balls, posi rear ends are for chebbys. Traction Locs are for Fords :nice:
And unless your car is 99.9% track car, i'd go with a clutch style locker. That is, unless you can afford one of those Eaton E Lock magnetic locking rear ends....you flip a switch and the rear end locks just like a Detroit does, but otherwise works just like a clutch style locker.
Just remember....when the rear end is locked, it doesnt like turning corners very much. Keep this in mind if you ever plan on going in any direction other than straight...also if you plan on driving in rain, gravel, grass or any kind of loose terrain. :D
I have a detroit in my car and I would NOT recomend one to ANYONE who drives their car on the street. I had an eaton that worked really nice on the street but after I broke it I decided I better use something a little stronger. I would love to go back to the eaton
Have you ever driven a car w/ locked rear end?
i assume no, b/c i have a spool and i drive it everywhere sharp turns 3 pt turns, its all good, no problems.
you might here a little squeeking or buckling on hot concrete but its not a problem, and when you hit the gas the car goes straight, it doesnt tourque to one side like a posi does.
:shrug: anyone running a magnetic locker out there??
LOL, my last car was a 351W '83 with a C4, 4.56 gears and a locker, so yea i've driven one. I built the car specifically for "neighborhood" driving, because i had the car and the engine and wanted something fun to play with the imports with. With 275 tires on the back, the inner tire would scream and buck on a 90 degree turn, and in the rain going around the same corner was like driving in snow. Fun? Hell yes. Safe? Probably not. Illegal? Absolutely, that is if you get caught driving sideways on your way to Taco Bell.
Seriously, would i spend as much time posting opinions if i didnt know what i'm talking about?
Although....now that i read my previous post, the part about lose terrain doesnt quite make sense so i'll reject that one, as lose ground would actually make it easier to drive a locked rear end, unless you were driving hard and then you'd just have some sideways driving. I grew up out in the sticks where we didnt even bother with D-lockers, we just welded the differential together. :nice:
marine_2003 said:
I dont want to buy anything i cant use while driving the car on the road, while im in town working i drive my car back and forth to work. But i also want to have something that will hold up if i want to take it to the track everyweek.
Think of it like this.... There are plenty of people, myself included, who are still using stock dif's in the rear end, and i can tell you my car hooks and goes straight as an arrow, that is unless it's fishtailing. Needless to say, if you've got a clutch diff. that's not worn out, that's really all you're going to need, since you're not building a racecar. Detroit Lockers were great back when clutch rear ends were junk, but technology has resolved the weak link and you can have a traction lock rear end that holds up to hard driving. IMO, if you're making so much power that a clutch rear end won't do the job, then you should probably have the extra cash to spend on the E-locker, if you really really neeeed a locking rear end, but don't wanna worry about chirping tires and such.
I've got a locker in mine and I wouldn't change it. During cornering, the locker will not lock unless you hit the throttle. Therefore, I coast around corners. If I do have to gas it, I do it slowly. It really is not that bad at all. After 20 minutes of driving, you will get used to the nuances that a locker brings to the table. I did it for the piece of mind of knowing that both tires will burn when I want them to. Reliability is a huge concern of mine.
My preference has always been the stock traction lock rebuilt with clutch/spacer/clutch/spacer/etc. The best way that I can describe it is that I like how it "acts" on the street. I haven't tried the Auburn or any of the other clutchless traction locks however. I did the detroit locker for a little while until the noises (it made a clicking sound) and how it acted under power in a corner made me want to swap back to the stock piece. I've not had an electric locker in a Mustang but did have one in the rear end of a 4 wheel drive truck. I definitely did its job and made the rear a solid axle. I'm not sure if I'd like to have that in a Mustang or not. I just don't know.
I assume you had a Detroit EZ Locker? My Detroit doesn't bother me under normal driving. Mine does not make noise (except when it sticks) but at slow speeds you can feel the ratcheting. When you trying to turn around in a driveway or pulling in and out of parking lots it's shakes the entire car and sometimes it makes the car buck. It's just can be a huge pain. It's done it since it was brand new. Aside from that it works great both at the track and on the street.
I had an Eaton before and it had very nice street manners. If I wasn't so hard on it at the track I would DEFINATELY still use one. :nice:
I will agree with Daggar on the factory trac lock. I know in the begining before I started really modding my car the factory trac lock worked really well.
Right. There are different types of Detroit Lockers. I've got the NoSpin unit in mine. It doesn't ratchet around corners. Like kck6894, mine will shake if I'm turning slowly in a parking lot. I'll just stop and then proceed without incident. I swear that it's not that bad. I've got 11,000 miles on it since it was installed last year and I still wouldn't go with anything else.
