Possesed throttle control
I haven't had time to look into the problem yet but here is what is happening. On acceleration the RPMS stay high after I take my foot off the accelerator, as though cruise control is on. Tapping the pedal lightly will bring the rpms back down to idle almost like there is a mechanical problem with the throttle cable. It is really upsetting because sometimes when I leave it in gear to coast and slow down the car maintains speed and sometimes even accelerates on its own. The rpms don't hesitate then drop they just stay around 2k and sometimes speed up to 4k if I let it. once again, touching the throttle pedal releases the RPMS just like tapping the brake during cruise control would. Very Toyota Pruis.
My thoughts are a crimp in the throttle cable, a malfunction with the accelerator pedal, the TPS being wonkey or the throttle body sticking.
Anyone dealt with this **** before?
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I had a similiar problem several years ago. In my case, it turned out that the wire loom that runs under the throttle body was causing the throttle linkage to hang up.
Just something to check.
