- Apr 23, 2023
- 205
- 37
- 38
So have a 2005 Roush convertible with 38,000 miles. Last week hit the trunk release on my key fob and nothing. Assumed the battery died in it. Started the car and went to put it in gear and no go. All my dash lights were lit up too. Was able to override the shift interlock to get it home but had no lights at all and no radio. Pulled the BCM and saw some corrosion but not alot. Cleaned off everything I could. Put it back together and still have the same problem. Gonna pull it back apart again and look for any other signs. Looked online for another BCM but the ones I have found look worse than mine in terms of how much green 'corrosion' dust. I cleaned it using 91% alcohol, q-tips, and scraped the pins with a butter knife.
Gonna try to bend the contacts back out a little in the plug end to see if that helps. Would there be any BCM codes to read? Any other ideas? Anywhere else I should look? Any good places to find a good used BCM?
