possible distributor gear stripped... need help
  • Thread starter Thread starter black_demon
  • Start date Start date May 9, 2009
black_demon
474
Daly City
May 9, 2009
  • May 9, 2009
66 Coupe
289 bored .30 over
351 firing order
cam specs - D302-6250-A???
i'm driving along a few days ago and suddenly my motor isn't giving its full power so immediately i know i need to get off the freeway and hopefully baby her till i get home. with no such luck, the ol' girl gives out and i get towed home. i get home and immediately pull the cap off and spin the motor by hand and the rotor no longer spins. i pull off a valve cover and spin the motor again and the valves are moving so at least i know its not the chain. so thinking the only thing left is the distributor gear and am planning on stopping by the local speed shop and pick up a new dizzy but what type of gear would i need?? iron, steel or bronze? the specs are all above all work done to the motor were done by the previous owner so i really dont know what cam is in there except for the little info i put up found from some paperwork given to me when i bought the car.
also, if the gear is stripped pretty bad, do i need to pull the motor?
mrmustangman357
763
May 9, 2009
  • May 9, 2009
you should pull the pan and timing cover to get the chunks out of there
Dropping an Oil Pan - 65 Mustang - FordMuscle.com Forums
same thing. roller cams usually need a steel gear, hydraulic rollers typically a iron one. I haven't heard good things about durability of the bronze ones
2+2GT
3,333
10
79
Southeastern Pennsylvania
May 9, 2009
  • May 9, 2009
black_demon said:
66 Coupe
289 bored .30 over
351 firing order
If the gear is stripped, you'll need to pull the pan, and clean out the debris. It may just be the pin that holds the gear on the shaft. Pulling the distributor is easy.
Why the D30Z-A cam? The C9ZZ-C would be what you'd find in a 69-70 Mustang. And it wouldn't be hard to find a better one than that, the C9OZ-C would be even better, although it switches you to the 289 firing order.
latamud
791
Tampa, FL
May 9, 2009
  • May 9, 2009
Pull the distributor and you will know for sure if its the gear.
black_demon
474
Daly City
May 9, 2009
  • May 9, 2009
the previous owner had the cam put in, the only reason i put that info up was because i wasnt too sure on whether i need an iron or steel gear for the replacement... but i will soon find out when i pull the dizzy off.
H
htwheelz67
444
mission viejo ca.
May 10, 2009
  • May 10, 2009
you could have just snapped the pin that holds the gear on
J
Help - SCT Woes
  • James banks
  • Jan 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Resolved Does anybody recognise this distributor gear?
  • x_man586
  • Jun 4, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
x_man586
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
