For the solution and way to check skip to the asterisks, the story of how i figured it folows
Well,
I have been plagued with rattles in the back of the car for a good long time now, and because of how it was done (only hapened when the drive line was relaxed, went away when it was accellerating) i thought it was slop in the connections between the transmition, driveshaft, u joint, and differential. Finally today had pin pointed it. I usually work on my car myselg, by myself and so never had a chance to test my theory fully. Anyhow..
So i was changing my rear pads on the brakes, and was taking my sweet time with it as i was trying to fab a lil jig to turn the rear brakes with a socket, instead of having to use needle nose pliers... anyhow, once i was done and started to put the wheels back on (cars rear was still jacked up, i use the E brake to keep the wheels from turning when the back end is up) and when i tightened down the last lug i went back to the first one, and gave it a good yank (incase there was slack from when the others were tightened). when i did (pulling towrads the front of the car) i noticed it made the unmistakable sound that i hear every time i go over bumps.
So since i had moved in with my girlfriend a few months back I got her to come outside and yank on the bar still attached to the lugnut with the bar in a vertical position (yes i use the stock tire iron) while i got under the car. this put force on the axle and impacted the suspension like axle wind up, and here is the loving question kids, what controls axle windup.....
Upper control arms!!!! so yes, my UCAs are horridly sloppy, i get nearly 1/2" play in the bushing on the chasis end. its still secure so i am not worried about it braking.... however i will be ordering my trilink tomorrow
so, give it a shot on your car
Jack up the rear end, put it on jack stands(either under the axle or on the frame) use the tire iron to for the axle to spin (clockwise if looking from the passenger side) and rock it back in forth... crawl up under the car and see where the slack is... if its the two angled pieces that look like this __/__\__ then its yer UCAs... i am hoping this will be my big fix (as this has been an astonishing annoyance to me) that makes me happier with my car.
Hope this helps those with back end rattles like me.
Torinalth
Well,
Torinalth
seriously... rotating clockwise on the passenger side will induce axle windup, thus stressing the UCAs... to test the LCAs, go clockwise on the drivers side, rip the rod back and forth... is ther a lot of give. is there any give? LCAs are not typically an issue as they have stronger bushings, and more arm flex. anyhow, just yank on thhe axle with a tire iron on one of the lugs... see were you are getting flex/bending/movement. also, push on the wheel (pushing into the car) and see if you get much side to side flex.
