possible Head gasket???
  • Thread starter Thread starter eagle87
  • Start date Start date Nov 25, 2005
E
eagle87
62
New York
Nov 25, 2005
  • Nov 25, 2005
I have no smoke and it's not in the oil. when I back up I have a little puddle of antifreeze. I notice my temp gauge waves back and forth by ten degrees. It goes from 180 then to 190 then back again. would a compression test help Thanks for your help............
ram360
2,162
Pennsylvania
Nov 25, 2005
  • Nov 25, 2005
could be just a leaky hose or water pump making the puddle. I really wouldn't worry about a 10 degree fluctuation in temp either. Just me.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 25, 2005
  • Nov 25, 2005
Yeah, sounds more like a leak.
Put a piece of cardboard under the car, and let it leak onto that, and get under (or over) the engine and see where it's coming from.
For a HG to leak outside the engine it would likely pour out, not drip.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Nov 25, 2005
  • Nov 25, 2005
it is more common for the intake gasket to be leaking coolant then the head gaskets. for some reason the 4 corners of the intake are prone to coolant leaks. check all the hoses and the little hole in the water pump on the bottom side for leaks that will let you know if the water pump is shot
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 25, 2005
  • Nov 25, 2005
Put a piece of cardboard under the car, and let it leak onto that, and get under (or over) the under and see where it's coming from.
Excellent advice. The leak could be from the water pump, radiator, lower head bolts or any one of the hoses. This suggestion will help you find the leak.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
