possible Head gasket???
eagle87
62
New York
I have no smoke and it's not in the oil. when I back up I have a little puddle of antifreeze. I notice my temp gauge waves back and forth by ten degrees. It goes from 180 then to 190 then back again. would a compression test help Thanks for your help............
Yeah, sounds more like a leak.
Put a piece of cardboard under the car, and let it leak onto that, and get under (or over) the engine and see where it's coming from.
For a HG to leak outside the engine it would likely pour out, not drip.
it is more common for the intake gasket to be leaking coolant then the head gaskets. for some reason the 4 corners of the intake are prone to coolant leaks. check all the hoses and the little hole in the water pump on the bottom side for leaks that will let you know if the water pump is shot
Put a piece of cardboard under the car, and let it leak onto that, and get under (or over) the under and see where it's coming from.
Excellent advice. The leak could be from the water pump, radiator, lower head bolts or any one of the hoses. This suggestion will help you find the leak.
