I am having a vibe problem with my car.
I now have solid motor mounts and installed them due to thinking my stocks ones where bad. The vibration was there before the motor mount swap and has not gotten better or worse after I installed them. So it now seems to be coming from the driveline and not the motor. I have a new tranny and clutch as well as aluminum driveshaft. I have put a little over 6000 miles on all 3. When I 1st installed my aluminum driveshaft I could tell right off the back how great it was especially on the highway. Now I cant even tell I have one anymore because I have a vibration and it feels as if it might be my rear end itself causing it. The vibration occurs the most between 2800 - 3200 rpm. When I take off I have a slight shutter at times and it feels as if I loose a little bit of grip then regain it. Almost as if I am driving in the rain and take off on a painted line then the tire spins on the line and gets its grip back once off the line and back on the road. Hopefully you can understand what I mean by that. I also feel like I have lost power because of it. Should I install new hardware onto my driveshaft and possibly a rear end rebuild? This is driving me crazy!
