Post Pypes O/R H pipe install
I installed my h pype last night. I like the sound overall. However, I notice new sounds that I did not hear with my stock cat's.
My main issue with this h pype is that when I hit 3000-3100rpm's, I hear this wierd sound. Some ways to desrcibe it is tinny, light rattle (not a clunking sound), or a LOUD vibration. The harder i hit the gas - the louder the sound becomes. This is the only rpm where I have this sound.
I tighted up the bolts again and am not to sure what this could be.
Is anyone else encounter these sounds? I am running the Pypes O/R H pipe with flowmaster A/T's.
Thanks.
Nick
Kool should be in soon to comment on this. He had the Flowmasters with the Pypes O/R H. I'm wondering if it's pushing so much air through that's it's actually loosening the baffles in the Flows.
I don't have a torch so I just cut a little notch in each bracket with the cutting wheel on my dremel. It isn't the prettiest fix but it worked. I would be very surprised if this isn't the same issue you are having.
Yes, those are the heat shields I was talking about.
You could get some resonators put in after the H pipe. It would be a lot cheaper than getting a catted h pipe. Or, you could go with quieter mufflers, like GTA's.
Dark - I am not to sure what to do. I noticed since the install of this H pype - there is a much richer smell of exhaust. I think I want to keep the cat's on for the emmision purposes. I heard if I am caught without them in NY - i can get a HUGE fine. I got pulled over sat night for excelerating to fast when a light turned green (and there was a cop behind me which I did not know :chair: ) and I beleive the reason I did get pulled over was b/c of this exhaust. The car sounds like it is going a lot faster than it really is.
I am sure I could sell these on ebay or on the classified forums. Only had this H pype on for a few days.
i daily drive mine. you learn to drive around the sound. the first week or so is a learning curve. this combo is no bad as long as you learn how to accelerate. i say give it a few days and see how it grows on you as you relearn the curve.
if you are worried about the emissions related problems, i understand the reason for taking it off. if its just the sound, give it a little bit. :nice:
Thanks Big - appreciate it.
The sound that occurs from 3000-3100rpm is pretty bad. I am going to bring my camera in my car tonight and am going to get a sound record for you guys so you can hear it. The car sounds fine with a easy acceration - but when I punch it to merge into traffic - i want to :ack: when i hear it!
I believe its that heat shield - but I am not to sure what I can do to get rid of that sound if it is it. That shield is there for a reason and I don't want to remove it.
I've driven mine with the Flows & Pypes O/R H for nearly 26K miles since last March and I still love it:drool: Don't know if yours is rattling against something or not, but there are times when under certain load conditions and RPMs it almost makes me queasy from the sound pulses:D :nice: As far as loudness goes, big is right. You will learn to drive for sound. Where I work has cops all over the place and I've been in front of them at red lights and when the light turns green I baby it until it shifts into 2nd. I've never been pulled over...yet.
