i installed a vortech s trim, 42# injectors. nothing more, nothing less engine wise. along the way until today, it had no serpentine belt. i started it a few times, barely revved it and all was fine.
today i put on the remaining pieces for my serpentine belt routing. consist of larger ps pulley, wp pulley, fms a/c delete which moved the ps up. thats it. belt was real tight with tensioner, needs to be as small as possible for clearnace.
car starts and idles as far as i can tell, endlessly. no issues there at idle with it dying. car idles low almost like its got a partial load on it however. like 650 rpm's. when i touch the gas, i get a hiss sound, fuel pressure increases and it drops rpm's. it drops rpm's and will die if i keep my foot on the gas, or it will recover and continue to idle.
we have tried the following to trace it; removed primary belt and sc belt, unplugged maf, solid fuel pressure, removed inlet tube for free flowing air completely around sc, no codes, i think thats it....
anyone got an idea? what could cause it to reject any throttle application like this? the steering is also VERY stiff. pump turns fine by hand, belt is definately tight but i even pulled the tensioner off and no improvment to steering feel. no obstructions or anything near any steering components.
