Power difference between heads with 2.02 vs 1.94 inch valves
SadbutTrue
2,390
Granada Hills, California
I'm looking at getting aluminum heads. I don't think I can ones with 2.02 inch intake valves anyway because they'll interfere with stock pistons, but in any case....
How much more power does a setup with make with more aggressive valve size? Is it worth changing pistons for? Whats the largest size you can run with stock pistons?
You can run larger valves without special pistons if your cam lift and timing allow.
Like said, there are way too many variables to post a yes or no answer.
It is one of those deals where you have to mock up your engine and check valve clearance.
Technically, to build a performance engine properly you are supposed to check valve clearance regardless. If you have clearance issues, then you either use a smaller cam, shorter rocker ratio, or mill the pistons. Then you check clearance all over again until you get it right.
As for power...
It is all relative to your rpm.
Larger valves will make significantly more power, but depending on variables, it generally doesn't show up until higher rpms.
You can also lose lower rpm power, depending on your combo, if you go too big.
The difference between 1.94" and 2.02" intake valves will be minimal though. I am sure it could be as much as a 10-15 hp difference at 6000 rpm, but much less at street revs.
Dave
HistoricMustang said:
Heard a few stories of Twisted Wedge heads cracking in the spark plug area and have also heard some racers talk about getting valves too large for the 289/302 engines.
Mine are Edelbrock RPM.
HistoricMustang
www.historicmustang.com
A lot of them crack in the spark plug area but it doesn't affect their performance.
I've had them all except for canfields and brodix heads.
I'd be more concerned with the cracks that occur inbetween the valve seats. Since the seats are cut so much it creates a weak point where the two seats overlap.
