  • SN95 4.6L Mustang Tech
Power Lumbar Seat Problem
  • Thread starter Thread starter ejbrandt
  • Start date Start date May 25, 2009
E
ejbrandt
  • May 25, 2009
All,
My 2001 GT lumbar pump is not working. I am not the best electrician but I know I have 12 vdc at the lumbar pump motor, the book calls for 10vdc. So I ordered and installed the new pump, guess what it didnt work. I hooked the old pump up to the battery, it works.
So I shot the wires all checked good, I check the switch, its good. I hooked the pump up to the wires feeding the seat, the doesn’t work.
The fuse is good, not sure where to go. It seems like when you put a load across that circuit the voltage is not there... Any help would be appreciated...
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 25, 2009
  • May 25, 2009
Strange, almost sounds like your ground wire isn't grounding.
N
n0v8or
604
Rhode Island
May 25, 2009
  • May 25, 2009
You've done a pretty good job of troubleshooting the problem so far.
With the switch on, the Black/White wire to the pump should measure battery voltage (~12V-14V), and the Black wire should measure 0V.
If the Black wire measures 2V or higher, there is a bad connection in the wire to Ground (connector; ground lug; or frayed wire), as suggested by Rusty67. If the Black/White wire measures less than battery voltage, there is a fault somewhere in the positive wiring (switch; connector; or frayed wire).
These measurements have to be made with the pump motor connected.
E
ejbrandt
  • May 25, 2009
thanks, I will try those measurements...
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
