Power pipe questions
There are a couple different versions of the power pipe. With couplers you can put the meter out in the fenderwell. No need to recal the meter for just the pipe. Don't forget to buy a conical filter. they don't come with them (AFM anyway... don't have a clue about UPR).
Edit: Kinda pointless to get a power pipe if you intend to use the stock meter, isn't it?
they make a 2nd type of powerpipe that actully puts the MAF right next to the throttle body. its the better option if your gonna keep the stock MAF
Here is my 4" powerpipe with the 80mm MAF in the fenderwell.
The meter sits down in the fender at the end of the pipe. The UPR pipe is a near identical piece of the AFM I've had them side by side..... It comes down to plastic or powder coated steel as your choice. They both are set-up for a Mondo bypass so if you are not using the large bypass you need to make some custom set-up for your bypass valve, not a big deal though...
The pipe Nate metioned is a the NA pipe made for 75mm Pro-M's which do not like to be at the end of the pipe on a NA application. The large pipe like Nates uses is for the 80mm Pro-M which doesn;t care where it is in the intake track.
