  • SN95 4.6L Mustang Tech
power source by shifter isnt working
  • Thread starter Thread starter steveb24
  • Start date Start date Dec 17, 2006
steveb24
555
wilmington, DE
Dec 17, 2006
  • Dec 17, 2006
im getting no power to this source. the fuse i found by reading the confusing owners manuel led me to a fuse which was cracked down the middle in the box under the steering wheel. i replaced it and still no power. idk what to look for now or why its not working, ive seen others in the search thread with this prob but nobody said how they fixed it. can anynody help me out?
W
WillDuhhBeast
339
Jacksonville Florida
Dec 17, 2006
  • Dec 17, 2006
I have the same problem, mine doesn't work, and i don't know why. I even attempted to rewire the whole setup, still not luck.
steveb24
555
wilmington, DE
Dec 17, 2006
  • Dec 17, 2006
i dont think mine worked when i got the car. can somebody clear up if the fuse for that source is under the hood or under the steering wheel? im just getting ready to buy a passport 8500 x50 and now this crap! im so pissed. i know the wires in there good too cause it clicked when i snapped it in after installing my shifter. it was a pita to clip in too.
steveb24
555
wilmington, DE
Dec 17, 2006
  • Dec 17, 2006
ideas?
san~man
O-G
A little grass shack on a big lava rock
Dec 17, 2006
  • Dec 17, 2006
Did you take the console apart and check to make sure it's plugged in? Stupid idea, but just a suggestion.
Duke309
90
Orlando, FL
Dec 17, 2006
  • Dec 17, 2006
the fuse might have blown again? You might try and follow the cable and see if its cut anywhere.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 17, 2006
  • Dec 17, 2006
Should be fuse #1.
Reactions: rufeo690
steveb24
555
wilmington, DE
Dec 18, 2006
  • Dec 18, 2006
i replaced the fuses, it was plugged in. then i read something about.. in a search.. that its a green fuse under the hood? is that correct?
the98stang
2,408
Clovis, CA
Dec 18, 2006
  • Dec 18, 2006
Do you mean the ciggy lighter isnt working?
Look at the chart posted above and replace the specific fuse...
steveb24
555
wilmington, DE
Dec 18, 2006
#10
  • Dec 18, 2006
  • #10
ok let me say this again.. i replaced the fuse. the cig lighter in the center console works, so wouldnt they be on the same fuse anyways? the wire isnt cut, gashed or anything. still no power to the outlet by the shifter. would replacing the outlet do anything? i tried hooking the working one up on the broken outlets wire, but the connector pieces are different. im still at a loss and really want to have this fixed. its this little stuff that really bugs me.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 18, 2006
#11
  • Dec 18, 2006
  • #11
I would test the voltage coming to the back of the actual cigarette lighter socket with a multimeter. If you have 12V to that point, then the actual socket/lighter is likely faulty. If you do not have 12V to the socket/lighter, then you likely have a faulty circuit or wiring problem.
steveb24
555
wilmington, DE
Dec 18, 2006
#12
  • Dec 18, 2006
  • #12
whats the tool called that tests it? also, i was wondering if u think it would be possible to move the other cig lighter to the spot by the shifter and keep the other one disconnected. it seems like it would work, but can somebody tell me how to remove the emergency brake handle?? i need to get that off to remove the console.
i guess i only need to remove the plastic visible piece. how do i do that?
merc123
420
North GA
Dec 18, 2006
#13
  • Dec 18, 2006
  • #13
Did you try replacing the cig lighter? It's only about $2 at the auto store.
steveb24
555
wilmington, DE
Dec 18, 2006
#14
  • Dec 18, 2006
  • #14
like the socket itsself? im going to try tht tomorrow. do i need to go to ford or what?
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Dec 18, 2006
#15
  • Dec 18, 2006
  • #15
steveb24]whats the tool called that tests it?[/QUOTE] [QUOTE=LaserRed01GT said:
I would test the voltage coming to the back of the actual cigarette lighter socket with a multimeter....
steveb24
555
wilmington, DE
Dec 18, 2006
#16
  • Dec 18, 2006
  • #16
iight imma look into it tomorrow
steveb24
555
wilmington, DE
Dec 19, 2006
#17
  • Dec 19, 2006
  • #17
well i wired the outlet in the center console up to the outlet by the shifter. for now i just pulled out the not working out and d/c'ed the wire n got it zip tied away. it works so all is good. im gonna get a cig lighter cover and out that over the hole in the console now.
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Z
Electrical Problem - Help Needed
  • zworley_10
  • Apr 11, 2023
2005 - 2014 S-197 Mustang -General/Talk- Apr 11, 2023
zworley_10
Z
