Power steering woes.
  • Thread starter Thread starter Edster
  • Start date Start date Oct 4, 2007
Edster
500
League City, Texas
Oct 4, 2007
  • Oct 4, 2007
I was rebuilding the control valve and slave cylinder and noticed the frame bracket for the slave cylinder was loose. I removed the bracket and noticed the mounting boss was loose. It turns out there are these pieces that slide into hexagonal holes in the frame which happened to be loose. I found out the pieces are known as rivet nuts in the fastener industry. It seems like who ever put power steering in the car (orginally manual steering.) did not properly install the rivet nuts by tightening them to the crush point. I was able to salvage one of them but the other was a lost cause. My dilemma is that I have not been able to find at any of the local fastener suppliers. And online it seems that you must have to order in bulk. Does anyone have any ideas where I can find one of these elusive fasteners or a part number than can be used to order them?
BarnStang
1,260
Hagerstown, MD
Oct 4, 2007
  • Oct 4, 2007
Any of the large Mustang parts vendors carry them. CJ Pony, Mustangs Unlimited, Mustangs Plus, Virginia Classic...I'll take a look and post a link
BarnStang
1,260
Hagerstown, MD
Oct 4, 2007
  • Oct 4, 2007
http://www.parts123.com/parts123/yb...~S2721B3WY524170221408b~Z5Z5Z5~Z5Z5Z50000016a
www.cjponyparts.com
Part # HW1151
TD68302
57
Arvada, CO.
Oct 4, 2007
  • Oct 4, 2007
Just weld the bracket to the frame, and you won't need to worry about it
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 4, 2007
  • Oct 4, 2007
Bad idea. What if he wants to change steering setups later ? Go to manual ? Switch to a R&P ? Go to an inigral power steering box ? Now you gota "unweld" that bracket.
Edster
500
League City, Texas
Oct 5, 2007
  • Oct 5, 2007
Thanks for the info! Wow! 9.95 is a bit steep condidering most fasteners are usually around 2.00 dollars at the most. But where else can ya find 'em!
TD68302
57
Arvada, CO.
Oct 5, 2007
  • Oct 5, 2007
You mean that they don't make spary on weld remover.
Thats what they make grinders for! I welded mine, then the bracket it itself broke about ten years later. Cut it off(unwelded), welded on new one. Problem solved.
R
ron67fb
1,117
SF Bay area, CA
Oct 6, 2007
  • Oct 6, 2007
Drill 2 holes in the rail and put nuts/washers on the backside. Has worked for me since 1992.
BarnStang
1,260
Hagerstown, MD
Oct 6, 2007
  • Oct 6, 2007
I have welded them on ocassion. Usually upon request. But, that's not what he asked for...and not everyone has the experiance and equipment to A. weld it on, or B. cut it back off. The crush nuts are a cleaner and original solution. It should be a last resort. If the hols are so rusted out that you cannot get the crush nuts to tighten up, then it's not always worth the time and effor to repair a hole like that.
Edster, it's not just a nut you beat into the hole. It;s a crush sleeve. Make sure you get the crush nuts in tight without the bracket installed. You should be able to put a bolt in the crush nut with a flat washer that covers the lip of the crush nut, but does not catch on the edge of the frame when you put the crush nut in the hole. Tighten down the crushnut till it's good and tight. You should be able to remove the bolt and flat washer, and it should remain tight in the hole. You can then put the bracket up and put the correct length bolts in place.
Edster
500
League City, Texas
Oct 7, 2007
#10
  • Oct 7, 2007
  • #10
Yeah tahtas how I destroyed one of the nuts was by trying it with the bracket. The othr one I crushed by using WD-40 on the threads and a frame washer (real thick) that enabled me to salvage the piece.
BarnStang
1,260
Hagerstown, MD
Oct 11, 2007
#11
  • Oct 11, 2007
  • #11
I thought this was worth revisiting in case anyone else has had to deal with this. Found this on the stangersite that someone put up in a related thread. The instructions there to install the crush sleeve say to put a nut down on the bolt, then the flat washer, then thread the bolt into the crush sleeve. Hold the bolt stationary,and turn the nut with a wrench to crush the sleeve in place. Hereis the link:
http://www.stangerssite.com/framebrackets.html
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
P
1964.5 289 Convertible - power steering hose routing bracket question
  • planters49
  • Nov 1, 2024
Classic Mustang Specific Tech Mar 6, 2025
manicmechanic007
A
Engine 99 V6 Steering Pump Replacement
  • abs68206
  • May 23, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2025
abs68206
A
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
