Power to manual seat track question
  • Thread starter Thread starter dubbsix
  • Start date Start date Apr 21, 2009
dubbsix
347
Katy,TX
Apr 21, 2009
  • Apr 21, 2009
Did I assemble the manual track correctly? I took my best guess on where the springs should go:
Me totally confused:View attachment 261001
My best guess
E
erzats
74
  • Apr 22, 2009
No. The large spring is in the correct hole in the first pic. You then pull it back to a small hole that is under your seat cover flap rearward. This spring is what makes the seat go forward when adjusting. You will know when you have it right because the seat will go forward by itself when you move the lever. Just did one of these yesterday .
dubbsix
347
Katy,TX
Apr 22, 2009
  • Apr 22, 2009
Thanks. Anyway you could provide pic on which small hole the spring goes into? There were a few holes. One right before the threaded whole for the seat to seat track bolt.
thanks in advance!
T1 3VOM
Maryland
Apr 22, 2009
  • Apr 22, 2009
If I remember correctly, the spring attaches here. You can't see it in the picture, but I'm pretty sure it's there.
dubbsix
347
Katy,TX
Apr 22, 2009
  • Apr 22, 2009
I will have to go home and look at it close up. I cant tell from the picture either.
T1 3VOM
Maryland
Apr 22, 2009
  • Apr 22, 2009
Wait, no... that can't be right... can it?
Anyway, now that you know the general area, it should be pretty straight forward.
dubbsix
347
Katy,TX
Apr 22, 2009
  • Apr 22, 2009
lmao, well thats what im asking you guys
I know that there didnt appear to be a hole or slot where your arrow is pointed. There were a few small holes near the seat to track mounting bolt hole though. Anyone else give us a bit more clarity on where the spring connects to?
E
erzats
74
  • Apr 22, 2009
That spring is attached to the bracket in the front and the seat under the upolsterry flap you have. there is a couple of small holes I believe either will work. In your first pic if you pull spring almost directly back you should find the hole. It must be from bracket to seat though as this is what makes the seat come forward when bracket is released.
dubbsix
347
Katy,TX
Apr 22, 2009
  • Apr 22, 2009
thanks!
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
M
WTB Seat track
  • Magnet86
  • Jan 15, 2026
  • Want to Buy
Want to Buy Jan 19, 2026
Magnet86
M
