Hello,
A couple days ago my drivers window went out in my 01 Mustang Gt vert. It is stuck in the down position so I can't get to the motor. How do I get the window up so I can get to the motor? Also, how do I find out if it is just the bushings instead of buying a new motor Any help is appreciated.
i havent figured what the problem is though. every time it gets stuck down, i have to take off the door panel and when the door panel if off, then it will roll up. if you really need the window up and the motor is shot, heres a trick my automotive instructor taught me. take two booster packs (24 volts) and hook them up in series. then connect the leads to a set of alligator clips and connect them to the wires going into the motor. the motor may not work on just 12v, but it WILL work on 24v
. other than that, im really pissed right now too since im NOT going to rip off my door panel everytime i need to roll up my window
