I have an urgent problem. When I got to work today I noticed that my driver side front window will not raise!!! It is in the full down position. It is supposed to rain tomorrow so I need to get this figured out soon.
My other windows work flawlessly so it can't be a fuse issue. When I press the down button i hear a click in the door. When I press up... nothing. I guess there are 2 possible causes. 1- I have a bad switch. 2- I have a bad motor.
My idea is to t-tap into the wire that leads to the up button. Once I have the wire tapped, I can then touch a metal contact to the bare lead to try to active the motor to push the window up.
Any help or recommendations would be GREATLY appreciated.
By the way this is URGENT. I dont want to get all wet on my way to work tomorrow.
I woke up, went to the garage. Took a screwdriver, placed it on the motor, hit the screwdriver with a hammer....voila the window is now up.
. Hope someone here can help
