power window problems...help.
fiveoho
1,958
TN
passenger side window on my 90 fox will not work from either switch, passenger side or drivers. this problem has happened before prior to recently installing a new window motor. after the new motor, it worked great for a few months. now it doesn't - the window will not move one bit. fortunately this time, its stuck in the up position. before the new motor, i could hold the switch down and thump the door panel above the speaker and it would sometimes start working.
any ideas guys?
interesting. i did not realize the power originated from the drivers side.
side note - when i said i 'thumped' the door panel, i did that to the passenger side panel.
