Power window question, bad switch?
  • Thread starter Thread starter 87lc2
  • Start date Start date Sep 27, 2011
87lc2
214
Sep 27, 2011
  • Sep 27, 2011
This is the wifes car, 90 GT Convertible. She went to put the window up and it stopped halfway, no noise from the motor at all, banging the panel didnt help.
When I got home I took a look and noticed all other windows working fine except driver side. When I hit the switch the volt gauge does not move, does that indicate the switch is not closing the circuit? I doubt its the motor as there were no problems before this, didnt get slow, intermittent, etc. Going to look it over some more tomorrow, just wanted some opinions.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 28, 2011
  • Sep 28, 2011
Power Window tips & tricks
Motor removal & replacement
Remove the door mounted speaker & the upholstery panel to gain access to the motor. There are 3 screws (5/16" hex head, I think) that secure the motor in place. Remove them and the motor comes out without any problems. Once you remove all the screws from the motor, and it falls away from the gear teeth on the arm for the glass, the glass will move up and down. You may need a helper to hold the glass once the motor screws are out, since the gear on the motor holds the glass from sliding up or down
Motor interchange
The motor is the same for left side or right side, only the gearboxes are different. If you can't find the complete assembly for the side you want, you can get either side and use the old gearbox on the new motor.
The window motor gearbox has 3 plastic rollers that are a safety clutch to prevent possible injury if the window is rolled up while something or someone is hanging out the window. The plastic rollers will often disintegrate into chunks of plastic and the window will no longer roll up or down. The motor runs, but the window does not move or only move a little.
The Help! section of your local auto parts store will have the replacement plastic rollers.
See NAPA Window Regulator Gear Plug
Napa p/n BalKamp 6651524
Cost is 9.49$
AutoZone and other auto parts stores see Dorman 74410 / Window Lift Motor Gear Kit
Cost is $7.99
Power Window Wiring Diagrams
Diagrams courtesy of Tmoss & Stang&2birds
87-92 model cars power window wiring:
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 model cars power window wiring:
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark
87lc2
214
Sep 28, 2011
  • Sep 28, 2011
Happen to have the diagram for a convertible?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 28, 2011
  • Sep 28, 2011
Both diagrams cover convertibles...
LarsD
2,680
119
123
Texas
Sep 28, 2011
  • Sep 28, 2011
This happened to me and it was the switch. I verified it by pulling the driver's door switch panel out and swapping the passenger switch with the driver's switch. Once I did that it worked fine. Assuming verts are the same as hatches I'd give that a shot, it quick and easy to try.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 29, 2011
  • Sep 29, 2011
Good point
Taking the switches out and cleaning them with electrical parts cleaner or non-flammable brake parts cleaner is a recommended procedure. I fixed one window problem by doing just that.
Electrical 1986 Mustang GT Multifunction Switch Question
  • Willybill32
  • Oct 26, 2025
Fox 5.0 Mustang Tech Nov 22, 2025
Willybill32
Electrical Fried my window motor…
  • AnthonyA1234
  • Oct 25, 2024
Fox 5.0 Mustang Tech Oct 26, 2024
General karthief
Resolved Ignition switch questionable
  • Dontknowchit
  • Mar 14, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
General karthief
Electrical Power seat motors don’t go forward and backward
  • AnthonyA1234
  • Oct 13, 2024
Fox 5.0 Mustang Tech Dec 18, 2024
jeremyzcook82
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
