Get the vortech SC Trim. Its not hard to install, me and a friend did one in 8 hrs. There are alot fo people on here with the SC and they like it no complaints.
I'm fed up with a few things but the icing on the cake is that the acc belt doesn't fit. I'd have to spend more money and buy a bigger PS pulley and a smaller water pump pulley and then try another belt. Also the fact that I absolutely HATE how tight everything is. Overall the install isnt too bad. I just want to go back to my original plan of a 342/347 stroker. Let me know if anyones interested.
Im interested in the blower. I'm nor sure nof the changes I need to make to install it thought. I have a 347 w/ 10.7 compression and heard that I need to lower it?
god 10.7 is way too much to boost. I believe the optimal compression ratio is around 9 or under to boost, although people may boost higher compression motors. As far as I know, all you, at this point, could do to raise compression would be to get some thick head gaskets, and I don't even think that would be enough. Alternatively, you'd have to get new heads and/or dished pistons. I do not, nor do I claim to know everything, so someone let us know if I'm wrong.
Green92LX: Couldn't you just try different size belts? Surely you can find one that will fit w/o changing pulley's out.
